dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Sep 12, 2017 #1 lithium jump packs have been around for a while now and one successfully jumped a big diesel engine with one yet?
Focus Owner is rather bored Parked in the garage Joined Jun 30, 2007 Messages 14,173 Points 1,990 Location In a house Sep 13, 2017 #2 lithium battery cells especially 18650s give quite a hell alot of amps, even got portable welders with em in now. https://www.wellyweld.com/products/fronius-accupocket-150-240v-battery-welder-73067.aspx should be fine in my opionion, even small batteries give 40 amp http://www.ebay.co.uk/itm/4x-4S-14-...869287?hash=item25db1c84e7:g:Ng8AAOSwf~9ZZ0cU 40C apparently means 40 times discharge rate to amps so 52 amp per battery, Last edited: Sep 13, 2017 This post contains affiliate links which may earn a commission at no additional cost to you.
OP OP dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Sep 13, 2017 #3 Focus Owner said: lithium battery cells especially 18650s give quite a hell alot of amps, even got portable welders with em in now. https://www.wellyweld.com/products/fronius-accupocket-150-240v-battery-welder-73067.aspx should be fine in my opionion, even small batteries give 40 amp http://www.ebay.co.uk/itm/4x-4S-14-...869287?hash=item25db1c84e7:g:Ng8AAOSwf~9ZZ0cU 40C apparently means 40 times discharge rate to amps so 52 amp per battery, Click to expand... um neither of them are jump packs This post contains affiliate links which may earn a commission at no additional cost to you.
