Thread Tools
Old 06-03-2017   #1
Parking in gear
What are people's thoughts in parking in gear rather than in neutral other than on hills? Always something I do since passing my test. Any thoughts do you do it? What about on your drive or in your garage?
MattHarris19872016 is offline Reply With Quote Quote
Old 06-03-2017   #2
Re: Parking in gear
Ey up. Mat hope you are ok and alls good. I always park my car in gear I just want to make sure it doesn't roal off plus I don't stretch the hand break. All so I always press the couch when I start up. It's a harmless habit, your car your rules. My regards Phil. Enjoy your evening my regards Phil :-)
Likes zedorio liked this post
Phil wood is offline Reply With Quote Quote
Old 07-03-2017   #3
Trader Rating: 1
portland_bill has donated!
Re: Parking in gear
It's a habit that irritates me. But don't let me stop you.
Used to work in a large Rover dealer in Dorset 76-87. Workshop foreman always parked cars in gear. So we've had your car all day, put a blob of grease on the gearlever, relieved you of your life savings, and shown you we don't think the handbrake works. If we can't be confident of the handbrake following a service, how dare we take your money.
The handbrake should be capable of holding the car. If it is not, get it fixed.
Some modern cars will not hold themselves on engine compression. Corsa D 1.4 never did when we used them with BSM. Park on hill, Put into gear, release handbrake, car rolls to first compression, then slowly pushes over, onto the next, gradually gathering speed.
Current Fiesta 1.0 turbo won't hold on compression either.
DVSA advice says when facing uphill select 1st gear, when facing down, select reverse. That will turn the engine the wrong way. That advice frightens me. There's no evidence that compression would be greater in reverse. However, timing chain or belt will now be untensioned, as the tensioner will be operating on the slack side. Perhaps that's the reason for the advice, as it moves away down the hill, the belt or chain slips, piston hits valve, mechanical stop prevents car rolling.
Likes g8rpi, Phil wood liked this post
13 years motor trade, 16 years motor industry. 13 years Driving Instructor & 6 years Fleet Trainer
Panda Alessi
portland_bill is offline Reply With Quote Quote
Old 07-03-2017   #4
Re: Parking in gear
Never thought of it like that, what hill do you park on? If it's steep I use 3 clicks, enjoy the day my regards Phil :-)
Old 07-03-2017   #5
Trader Rating: 1
Re: Parking in gear
I've never counted the clicks. Push button, lift lever, keep tensioned, release button. Allowing it to click wears the ratchet mechanism. These are rarely lubricated by the manufacturer, relying on the oil film present from when it was pressed. I've seen them worn out in 18 months with people who drag them up every time. Can last a lifetime if used with care.
Manufacturers mostly now state in the handbook to allow it to click. This is a result of being blamed for inadequate application by the driver. Many people release some of the tension as they release the button, often dropping it down a tooth. This can be enough to allow the car to move. I insist all my pupils get it right, and don't drop the lever as the button is released.
Number of clicks will be dependent on size of teeth. Big teeth, fewer clicks. In the eighties, Maestro and Montego had fine teeth, and standard adjustment was 8-9 clicks. Many got tensioned to three clicks and then the self-adjusters don't work.
Panda Alessi
Old 07-03-2017   #6
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Parking in gear
Quote Originally Posted by MattHarris19872016 View Post
I don't leave in gear ever.
This comes from driving early diesels. If they did roll or got shunted and the fuel cut-off wasn't pulled out they could start and drive away. Generally think it's a bad idea. Also runs the risk of someone not used to it getting in your car, turning key and shunting into something. Another option is to turn the front wheels so the nearside one touches the kerb at an angle. The kerb then acts as a chock.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 07-03-2017   #7
Re: Parking in gear
Always park in gear with handbrake off ,unless on a hill. If car not used for a while it saves the handbrake sticking on .
Likes Phil wood liked this post
DavyP is offline Reply With Quote Quote
Old 07-03-2017   #8
Re: Parking in gear
I'm very much old skool & it's one of those things that on the face of it can cause no damage at all, & in my 40+ driving/working on cars, I've never come across damage by leaving a car in gear. However if you are stupid enough to jump into a car & are the type of person to immediately starts a car up, you could be in trouble, if in gear. An obvious well known habit if parked on an incline, is to obviously use the handbrake & position the wheels towards the kerb, depending which way you are facing. Simple. Leaving in gear as well ain't going to damage anything per say, just use your common sense when starting the vehicle again.
jimboy is offline Reply With Quote Quote
Old 07-03-2017   #9
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: Parking in gear
Never seen the point, even with my cars which are parked up for some time I don't leave them in gear either, just chock the wheels with the handbrake off.
Eklipze3k is offline Reply With Quote Quote
Old 07-03-2017   #10
Trader Rating: 1
Re: Parking in gear
Quote Originally Posted by DavyP View Post
Highway Code Rule 239
"You MUST apply the handbrake before leaving the vehicle"
This is law, so not applying it is an offence. Not sure how anyone would notice with an electronic one though. Unlikely to get caught unless it moves, or a bored copper notices.
Makes no sense with an auto that makes a physical lock in P, but that's been the law for as long as I can remember.
https://www.gov.uk/guidance/the-high...ing-238-to-252
Using the handbrake frequently, every time you park, and every longer stop at junctions and traffic lights, etc., actually prolongs the life of the cables, by keeping them free and moving. Not using them promotes them seizing up.
Likes g8rpi liked this post
Panda Alessi
Old 07-03-2017   #11
***** Whore
StevenRB45's Avatar
StevenRB45 has donated!
Re: Parking in gear
Only car I've ever had to do it on was a mk1 punto where the only thing pulling the handbrake did was operate the light on the dash (despite several garage visits).
Currently I do it out of habit if I'm parked on an incline but given it allows you to knock it out of gear without pushing the clutch on returning to the car it would suggest it doesn't roll at all anyway. If you have to push the clutch to return to neutral then it's moved in your absence.
StevenRB45 is offline Reply With Quote Quote
Old 07-03-2017   #12
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: Parking in gear
Quote Originally Posted by portland_bill View Post
Highway code is not law, but the "MUST" means there is a law that forms the basis of the rule. In this case its the construction and use regulation 107 http://www.legislation.gov.uk/uksi/1...ation/107/made
Note as well that's illegal to have your engine running when stationary (other than in traffic or to operate equipment attached to the vehicle) r have headlights or foglights on.
Robert G8RPI.
Old 07-03-2017   #13
Re: Parking in gear
Gentlemen, I think as adults we get the overall picture here regarding the OP. I've said on numerous occasions if anyone has read my bletherings, I always try to make my driving experiences & all that entails with information about topics, both upbeat & enjoyable. A bit of humour in the right places goes a long way in my book. Getting too hung up about certain facts can lead to willy waving conversations......
Just my thoughts.
Old 07-03-2017   #14
Re: Parking in gear
Oooops. Well got away with that for 63 years. Must remember in future to use handbrake more...
Old 07-03-2017   #15
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Parking in gear
I leave them in gear
My punto didnt have a good handbrake for a long time.... would NOT hold on hills....
So leaving in gear helped
To this day - i still do it!
why?
if somebody wants to steal your car onto a low loader - they could just snip the handbrake cables and yank it on alot easier
if the front wheels dont wanna turn easily either - then it makes it that little bit harder for them
So much so - the habit now is EVERY car i get into, i stick my foot on the brake AND clutch while starting incase its in gear and i've not checked
plus if it was in gear cause handbrakes ****e, i wont roll away either
ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Thread Tools
(T) Odd gear selection problem/floppy gear lever on 1.2 8v? Taipan Punto (Mk2/2b) 15 20-01-2015 08:18
(G) Gear Box Problems Fiat Ducato Motohome 04 1st and 2nd gear WayneFletcher Ducato 4 10-03-2013 09:45
(T) Gear problem, 1st gear hard to engage and reverse grinds very loudly. help please ? mygrande Grande Punto 15 08-12-2012 11:40
(G) Parking sensors sounding in first gear ;( Jayp Ulysse 2 23-07-2011 11:01
(G) gear stick play / steering wheel cover / gear knob Jamie1978 Scudo 0 06-12-2010 18:49
