Door handle
Door handle
mickie taylor
I am trying to fit a new outsidedoor handle on my fiat ducato 2008 and am having difficulty in removing theinside panel I have removed the two screws at the bottom and the two behind theinside door handle and I have tried to prise the small cap at the top left but Iam afraid to damage the plastic, I just can’t see how the grey plastic arm restcomes away to get at the black door panel as per photo, Any help would be muchappreciated.
hi , and welcome,
the Ducato section should have the correct info for you,
Charlie
Check behind the speaker / speaker cover
Also check behind the internal handle as well
Check there are no press fit flush fittings to cover screws up
alot of cars tho use pop fittings too - which sometimes just dont wanna play ball as you have to force them off
Sometimes they break - sometimes they dont
Ziggy
