| | Thread Tools | Search this Thread |
| | #1 |
Posts: 76,417 Thanks: 1255 Trader Rating: 10 | The car/light goods vehicle MOT test is about to change – the European Commission has changed the Directive that covers it. We take a look at when these changes are likely to come into effect and what they mean for MOT testers. Britain has been testing vehicles under the MOT scheme for 50 years now. Last year, the European Directive covering the MOT test was updated and revised by a modern version called 2009/40/ EC. This was then updated by 2010/48/EU, which was ratified on 5 July this year. The new Directive keeps the EU minimum 4-2-2 test frequency but adds a number of new elements to the British MOT test. The Directive anticipates all test changes being in place by 1 January 2012, and a common European approach to test certificates in place by 1 January 2014. So what is VOSA doing to introduce the changes? In terms of test frequency, in mid-July the coalition government confirmed that it intends ‘to look at the issue of MOT test frequencies later this year’. VOSA contributed statistical data to inform the last review in 2008, and we expect that our computer system and the data you have entered will be utilised again in much the same way. We expect to hear more details of the government’s review proposals later in the year. As far as changes to the test content are concerned, VOSA has already been analysing the requirements of the new Directive and working out how to implement them. We started this earlier in the year by talking with representatives of the MOT trade at our regular Trade User Group and VTS Council meetings. Both VOSA and the Department for Transport (DfT) are keen to ensure that any changes to the test are introduced in as practical a way as possible, keeping the burden on the trade to a minimum and ideally keeping the changes cost neutral. In many cases, the changes shouldn’t necessarily lead to an increase in average test times. A good example is the malfunction indicator lamps on the dashboard that indicate defective electronic power steering, electronic stability control and secondary restraint systems. Testers already check the dashboard for other lamps, so no extra time would be required for this addition to the test. Electrical wiring and batteries are now included in the test’s scope, but testers already check the vehicle structure where wiring is secured – often along the same routes as other testable items, such as brake pipes in the engine compartment. So again, this doesn’t look like an additional burden on the tester. In the precomputerisation days, testers often (wrongly) failed vehicles for insecure batteries, so they must have been looking at them then! Now, it means that when we implement the new Directive, vehicles can legitimately fail for battery insecurity, for no extra tester effort. http://www.dft.gov.uk/vosa/repositor...Oct%202010.pdf
__________________ Respect is something that should be automatically given to people. It is trust that is earned not respect |
| | Quote
| | #2 |
Posts: 76,417 Thanks: 1255 Trader Rating: 10 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl no one care then? in short HID lights – Specifically those aftermarket kits that give the very bright headlight beams. Any cars found with these kits will be an automatic MOT failure. Testers are able to easily spot the difference between HID kits, and manufacturer fitted Xenon’s. Easy to spot as Xenon cars have suspension level sensors, in car beam adjuster, and usually headlight washers. Chipped ECU’s - Unsure of just how/if this one will realistically be enforced, but any cars with chipped ECU’s will in theory be an MOT failure. I can only assume VOSA have found an easy way of checking ECU software through the cars OBD port (diagnostic plug). Wiring harness – The general condition of he wiring harness will be checked to make sure there is no rubbing or chaffing, and that the harnesses are in generally good condition. If unsecure, or damaged again MOT failure. Airbag warning lights - If any warning lights are illuminated, it will again be an MOT failure.
| | Quote
| | #3 | ||
| | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl I think fail for having a chipped ECU is a tad unfair, in some cases it improves an engines emissions. Spot on about HID's ban the aftermarked kits alltogether please
| | Quote
| | #4 |
Posts: 8,119 Thanks: 323 Trader Rating: 0 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl Finally Doing Something about Rubbish HID kits Wish people would realise you can get just as good lights by buying decent Bulbs to start with ![]() Lots of unhappy Car park Chavs are gonna cry now ![]() But you know what they'll do - they'll just swap back to normal lights and then when MOT is done, put HID's back in ![]() Ziggy
__________________ |
| | Quote
| | #5 |
Posts: 6,081 Thanks: 280 Trader Rating: 7 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl People with remaped ECU's dont always tell the next owner. What happens if you genuinely don't know your car has a remap? I guess the prices of "Tuning Boxes" will soon start to rise as everyone switches to the "Plug & Play" type tuning products. Just plug it all back in once the car has passed the MOT. Cheap HID kits are crap. Good quality bulbs in well maintained headlights are sufficient. Need more light, install a good quality set of spot lights.
__________________ I'm looking to buy 2 Fiat Blade wheels, anyone got some forsale? . ![]() |
| | Quote
| | #6 |
| | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl The remap/chip issue is an absolute joke everything else is fine.
__________________ Parts Wanted. I will consider any new original Fiat Bravo parts and 1.8 specific parts or HGT body parts you have for sale. ![]() My 1996 1.8 Fiat Bravo HLX in Ink Black |
| | Quote
| | #7 |
__________________ Black Punto SX MK1 - Peco Full Sports Exhaust System with Peco Sports Cat, Supersprint Manifold, K&N Induction Kit, 15'' Fox Alloys, Spoiler, OMP Strut Brace, anti-roll bar, GT Brakes, GT Centre Console, McKrich chip, Tricker Throttle Body, 1 sub, 2 amps, 6 speakers, and now a baby seat. No longer just a 55... |
| | Quote
| | #8 |
Posts: 11,443 Thanks: 398 Trader Rating: 0 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl That will be me ****ed then. I would need to replace all of the seats, refit steering wheel and rewire the horn. Then take off the remap when i finally get it. All to get an MOT. I just like to think of the extra miles i will need to do to achieve this. Not very carbon friendly is it now. EU is a Joke. The sooner we get out of it the better TBH.
__________________ Car Audio Goodness at its best for sale. http://www.fiatforum.com/classifieds...?product=28141 Last edited by volxstu; 11-11-2010 at 14:07. |
| | Quote
| | #9 |
Posts: 6,081 Thanks: 280 Trader Rating: 7 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl Interesting reading: http://eur-lex.europa.eu/LexUriServ/...74:0096:EN:PDF http://www.dft.gov.uk/vosa/repositor...ber%202010.pdf Remap Detection. As most dealers have online access to the default MAP's installed on their vehicles I don't think it would be to much trouble to allow MOT stations to have access to them. This would allow for the quick and simple comparision of the data stored on the cars eprom via the OBD port with the data stored online by the dealers.
__________________ I'm looking to buy 2 Fiat Blade wheels, anyone got some forsale? . ![]() Last edited by Shadeyman; 11-11-2010 at 15:44. |
| | Quote
| | #10 |
Posts: 76,417 Thanks: 1255 Trader Rating: 10 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl bump
| | Quote
| | #11 |
Posts: 361 Thanks: 14 Trader Rating: 0 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl I thought this was what they did anyway? Only has to meet MOT requirements for the actual test and not for the day to day running over the course of a year.
__________________ I tell it like it is so if I offend you.....Unlucky. Rule No.1: If it don't fit, make it fit. Rule No.2: If in doubt, kick or hammer it. |
| | Quote
| | #12 |
Posts: 21,701 Thanks: 1069 Blog Entries: 3 Trader Rating: 1 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl Few things come to my mind with this, and I spoke to an experience MOT tester yesterday. 1) There is no training planned so far, and its only 11 months away. 2) Airbag light illuminated indicates a fault. If the airbag and bulb are removed, no fault? 3) The manufacturers charge dealers to have the diagnostic information, about £250 per month per franchise. Fine if you get your car MOTd at the franchise, but what is supposed to happen if your car isn't that franchise, or its a smaller non franchised garage. Either its not gonna happen or the costs are going through the roof. Cheers D
| | Quote
| | #13 |
Posts: 76,417 Thanks: 1255 Trader Rating: 10 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl i hope it dont happen but the website its on seems legit? when it all went computerised a lot of small independents didn't think it would happen as some had never even turned on a pc before, but that happened
| | Quote
| | #14 |
Posts: 631 Thanks: 17 Trader Rating: 0 | Re: The car/light goods vehicle MOT test is about to change. airbag lights to be incl Re the remap issue. So what happens when a car turns up with an engine change such as a Cento with a 1.2 Punto engine? Or, as I have seen a 1985 Grandad with a twin turbo V8 in it?
__________________ ![]() AS part of the Government's new austerity measures, the light at the end of the tunnel has been turned off indefinitely. |
| | Quote
| | jdillon | Bravo / Brava | 13 | 29-09-2010 07:33 |
| | psychocandy | Punto (Mk2/2b) | 7 | 17-02-2010 14:26 |
| | BOFH | Punto (Mk2/2b) | 0 | 12-07-2009 18:30 |
| | discusbazz | Bravo / Brava | 24 | 28-06-2005 19:46 |
| | FamilyGuy | Marea | 4 | 18-11-2004 12:11 |
