Comment
Guide Tools
Make your stereo turn on and off with the ignition
Slippy
22-11-2005
A little tip for sei owners mainly but could easily be adapted for many fiats. <br />
<br />
I've seen it written on here that to get a stereo working in a sei (as well as other fiats) that what everyone does is to join the red and yellow wires together. This means that the ignition feed for the
Old 10-07-2012   #15
Re: Make your stereo turn on and off with the ignition
Hi I've just fitted a Fiat Original Visteon CD head unit and now the unit appears to be permanently powered??? Previously I had the Blaupunkt tape HU with a glove box CD changer.
Do I need to swap any of the pins to ensure it switches on and of with the key?
Thanks in advance for any advice.
Gazanib is offline Reply With Quote Quote
Old 27-04-2013   #16
Finland
Exclamation Re: Make your stereo turn on and off with the ignition
I have Fiat Stilo 2003. I wanted to put double din pioneer avic d3.
So I took off the stock cd player.
But The cables I got here is same as iso but the cabling is different.
Thus when i plugin player it does not turn on, it seems it does not have any power in it. But the stock player is working fine
In the picture A i only have 4 cable.
I dont understand what should I do?
Please help
Quote Originally Posted by jmsoares91 View Post
Any good tutorial with images ? I dont really get what's supposed to do ? Do I have to cut anything ?
What changes do I have to do ?
Thanks in advance
zahid44 is offline Reply With Quote Quote
Old 28-04-2015   #17
Finland
And you could just cut the wire from the originally ment fuse somewhere ib middle the road to iso plug and add micro relay.There are 16A relays in size 1x1.5cm or 1.6x2.0cm on 20A.Then with jump clip take signal for that relay from the ignition key.
That will not mess in any other function
longgo is offline Reply With Quote Quote
Comment
Guide Tools
