The FIAT Forum
Go Back   The FIAT Forum > Guides > ICE Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->All About Amps<!-- google_ad_section_end -->
All About Amps
Published by Luke
20-06-2005
Amp Features
1. Built in crossovers
A crossover can consist of both a high-pass and low-pass filter. What they do is filter out frequencies that aren’t within their set range. These can usually be controlled by a dial on the amp.
A LPF (low pass filter) will only let frequencies past that are lower than the set frequency.
A HPF (high pass filter) will only let frequencies past that are higher than the set frequency.
Using the crossovers allows you to set the amp to deal with a specific frequency range, which is highly important when phasing through your car audio system. This allows you to filter out all the high frequencies going to a subwoofer for example, or filter out the bass for the high range components, or both the bass and treble for mid range drivers!
2. Bass Boost
Some amps (usually mono bass amps) have a bass boost button or dial. This simply boosts the input signal between the 40 to 90Hz range to give more emphasis on the bass.
3. Speaker Level and RCA inputs
Some amps also have speaker level inputs as well as RCA inputs. Speaker level inputs allow you to connect a normal speaker wires to the amp and make benefit of using a standalone amplifier. This is good for those that don’t have a headunit with RCA outputs. RCA inputs are already levelled, and are much more common. These are better quality too compared to speaker level inputs – but if you haven’t got RCA ports, you cant complain!
4. Gain
The gain controls the sensitivity of the input signal of the amp. If you have it at full whack, you will have a much louder output, but also will distort much earlier when the volume is steadily increased. The common consensus is to keep the gain around half way
5. Remote input
This isn’t for a remote control, although some do have remotes that can be connected. In this instance it refers to a wire fed into the amp which switches on the amp when the headunit is switched on. This is a means of ensuring your amps aren’t switched on wasting power when they’re not needed.
Other parts of the amp should be the speaker output terminals and the power input terminals, but these are self explanatory I hope.
Contents
Article Tools
<<  <    Next Page: Summary (Page 8 of 9)    >  >>
Old 12-01-2008   #1
Got Fiat?
BumbleBee's Avatar
Trader Rating: (0)
BumbleBee has donated! United Kingdom
Re: All About Amps
Well that has cleared up allot of information for me, Thanks.
BumbleBee is offline
Old 08-06-2008   #2
Trader Rating: (0)
Re: All About Amps
Cheers really helped! One question though...I've found a package including a 1000W Sub with a 500W amp. Is this pointless if im also gonna be using the amp to power my speakers? Basically what im asking is will i have enough power lol
Foshcream is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
Article Article Starter Category Comments Last Post
Amps – The difference between all. Luke I.C.E 4 20-06-2005 15:29
what do ppl think of jbl amps? 99sei I.C.E 19 14-05-2005 11:38
Alternator amps? Jaff_Fox Panda (Classic) 12 08-07-2004 06:32
SPL X amps - need some info Sando I.C.E 4 24-11-2003 17:53
(G) wiring 2 amps together monster109 Stilo 3 17-07-2003 03:31
