The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🎵
Hi, is it still possible to get a code for my Fiat Scudo 2007 radio? Thanks
My numbers are below:
Car: Fiat Scudo 2007
Radio: PU-2294A
I'm not sure which numbers you need, so here are all of them!
SN: CL040161052112C
C6CBV1052112
C70000006246
286-8497-51
96 392 195 XT
I've already donated too ;)
Davren are you able to find my code ? Will donate if so [emoji106] thanks IMG_20190614_205120.jpeg
I'm really not sure which ones are the correct numbers to use, so here's everything there. I would really appreciate your help with my code.
815CM 85429 1852342
Fiat 199 MP3 S806 Small 2
7 648 542 316
034502
CM Nr
7 648 542 316
Fiat Nr
735 481 295 0
815CM 85429 1852342
7 648 542 316
034502
CM Nr
7 648 542 316
Fiat Nr
735 481 295 0
try this code 5415 (y)
Hi am I able to get a code?
The numbers I have are
BP - Nr: 7642375316 +
815BP2375341440746
I have already donated too :)
Thanks.
815BP2375341440746
Thanks.
You automatically get the gold "DONATED MEMBER" banner under you username when you've donated without usng the anonymous option. ;)
Also,there are too many digits in your serial number. It should be 815BP followed by 12 digits, not 13.
