The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Hey ? Can someone please help me with Fiat500 blaupunkt Radio Code
BP638389535432
7646383316
I have purchased a code from OnlineRadioCodes uk but it did not work. The code they gave me was 6453.
Thank you
6453 is the correct code for the serial number you've posted.
Check that you've posted the correct serial number.
Hello Davren could you help me with my radio code took the battery off to charge it and haven't got the code fiat no 735 523 958 0
CM-Nr
7 640 391 316
815CM0391A0951020
it's a Bosch unit
I have the code for you radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Use the PayPal button on the left under "Make a donation".... Do not use the button on the right under "Make an anonymous donation"
i need help with Fiat Ducato 2013 radio F250 FL code pls..
hw ver; 28378684
sw ver:046
prod date: 2413
ODM No: 2502
7355596850
33390676930076
DELPHI 034546
tnx in advance
hw ver; 28378684
sw ver:046
prod date: 2413
ODM No: 2502
7355596850
33390676930076
DELPHI 034546
tnx in advance
Sorry.... I don't have codes for Delphi radios.
You may be able to get the code from a Fiat dealer, alternatively you will need to get it decoded at a car radio workshop.
I'm a bit new to this and not sure if this will end up in the right place....
The radio in my son's Arbarth has suddenly decided to require a CODE,
which despite trawling through all of the paperwork I cannot find. We
have managed to take the unit out and found the following details:
Blaupunkt GmbH
815 BP829290776914
Fiat 312 SB05 S&S Black
7 648 292 316
There is also another label with:
73850178988 Fiat 312 Black MP3 SB05
I see from your forum that on occasions when you are able to locate
a code a donation is required. If you are able to help then this is not
a problem.
Many thanks
Blaupunkt GmbH
815 BP829290776914
7 648 292 316
a problem.
Many thanks
Blaupunkt GmbH
815 BP829290776914
7 648 292 316
a problem.
Many thanks
Thanks for donating to the forum. (y)
Your code is: 5124
Hi, code please!
Serial N M035911
Model AO
Fiat part N 735392560
Visteon part N VP4CF-18C838-AA
Thank you in andvace!
