The one and only code for fiat radio thread.
If you need a radio code, please do not post a picture of the radio.
For Blaupunkt radios, post the 10 digit part number (for most Fiat radios, this will end with 316), and the 14 character/digit serial number. For example BP123456789123.
Both numbers will be on a label on the radio. The serial number should also be stamped or engraved into the side of the radio.
Hello!
I have a fiat 500 from mexico, and after change the battery the stereo ask me from de code.
Unfortunatelly I don´t have the code card with the car documentation.
The decal of the radio says:
Supplier 33016
Date code 3501
P/N 28317093
(p) 1RZ26JXWAG
TxxYD350110096
7093M113500096
Also I want to know how can I make de donnation.
Please, let me know is it posible to recover the code :)
Thanks in advance for your help!
Best reagards,
Juan
Hello!
Supplier 33016
Date code 3501
P/N 28317093
(p) 1RZ26JXWAG
TxxYD350110096
7093M113500096
Best reagards,
Juan
Unfortunately, this radio can't be decoded from the serial number. The only way to get the code is from a Fiat dealer.
hi anyone help ive just bought an 05 fiat ducato van and require radio code
BP-NR 7 643 318 316
FIAT-NR 735 388 373
BP CODE ON RHS-BP331857209881
Many Thanks
BP-NR 7 643 318 316
FIAT-NR 735 388 373
Many Thanks
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
Hi
I need help
I need the code for BLAUPUNKT GMBH
Serial BP854391261741
Part no: 7648543316
Thanks alot...
