The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🎵
Hello,
Could you please help with providing a code for my Fiat Multipla Blaupunkt Radio/CD, details as follows:
Serial No 815BP237233959945
Part No 7 642 372 316
A donation will be made accordingly. Thanks in advance for your help.
Hello Alan,
That is brilliant and worked perfectly thank you. A donation has been made via PayPal.
Thanks again, regards,
JDP.
Requesting for the audio code for following serial number.
7 646 354 316
815 BP635499688425
Thanks in advance.
Regards
Shiva.
I can get the code for your radio.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
This is the 5th radio code you've asked for since you joined the forum earlier this year.
Because of this, I believe that you are using them for business purposes, so you will need to make a further donation for this, and any further codes you require in the future.
Hi, thanks for providing the code. I tried inputting it and it came up with the words CANCHECK but nothing else. Is this normal, any further help would be appreciated.
The CANCHECK message appears if you are trying to fit the wrong radio into your car. This could be because of different CAN (Control Area Network) systems, or because the radio needs to be connected to a CAN system when the car doesn't have one.
Hi could you get the code for my fiat punto radio please. I will make a donation for a working code.
Serial number:BP9373X5476236
Part number:7649373316
Many thanks,
Louise
Hi @ all, great forum here!
can anyone provide me the code of my Punto 188 - radio (Blaupunkt MID):)
Serial number is: BP137424835807
Part number is: 7 641 374 316
I will make a donation asap for working code.
Thanks a lot :worship:
Marc
Marc
