The one and only code for fiat radio thread.
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Re: Blaupunkt code
okies, i ripped my sisters radio out today,
the codes are:
7 642 347 318
BP234756230142
thanks peeps
I don't do many Nissan radios but your code should be: 1323
Please let me know if this is correct for my future reference.
To enter the code, switch the radio on, the display should show " CODE " then " 0000 "
Press preset " 1 " ... 1 time
Press preset " 2 " ....3 times
Press preset " 3 ".... 2 times
Press preset " 4 ".... 3 times
Once the correct code is shown, press the tuning up button " ^ " to accept the code.
Dave.
Re: Blaupunkt code
Hello
Is it possiable to get a code for my fiat ducato 2005 van with a Fiat Ducato CD High radio. it just has 'wait' on the display and won't move, don't know how long to wait though?
thanks
Re: Blaupunkt code
If the display shows " WAIT ", it means someone, has tried to enter the wrong code too many times.
Post all the numbers from the back of the radio and I may be able to get the code for you.
Once you have the correct code, you need to leave the radio and ignition on for about 2 hours or longer depending on how many times the wrong code has been tried. You will then be able to enter the code.
Dave.
Re: Blaupunkt / Punto radio code ?
Hi All,
Need sum help with unlock code, I have already donated and wondered if anyone can help me?
BP 7640377316
PROD-NR 7353243980
Tom
The numbers you've posted are the Blupunkt and Fiat part numbers for the radio. I need the serial number to get the code.
It should be something like BPX377XXXXXXXX
Dave.
Hello Dave,
Need code for the Blaupunkt 194 CD in 2005 Fiat Croma:
part # 7645 342 316
serial # 815 bp 534 253 724 390
will make a donation right now, thanks
Stevan
