Old 11-01-2012   #1531
Re: The one and only code for fiat radio thread.
Hi guys i have a fiat stilo abarth, when the battery was disconnected the master code request msg appereared!! I do not have this code and the only info i have is the serial number on the connect nav+ which is 735319233 and NPX003U2C?? I also have a IDC Ao9 cd changer! Please help guys, thanks
Lee800m is offline Reply With Quote Quote
Old 12-01-2012   #1532
Moderator
Davren's Avatar
Trader Rating: 1
Davren has donated!
Hi, Welcome to the FF.
Stilo Connect Nav+ units that were factory or retro fitted with the code do not loose the code when the battery is disconnected. The code is stored in the car's Body Computer so when the battery is reconnected the code is recognised by the BC.
You can get the code for an original factory fitted CN+ from a Fiat dealer from the registration number of the car. They will also need to see proof of ownership such as the car's registration document (V5). Price from a dealer for the code is usually about £30.
The only other way to get the code is to send the CN+ to Magneti Marelli in Italy. When I enquired about this 2 years ago, the price was €180 plus postage to Italy.
Do you know whether the CN+ was factory or retro fitted in your car?
I can get the code for your IDC-A09 CD Changer but you will need to post the serial number (BP and 12 numbers) stamped into the side of it and the part number (10 numbers starting with 7) from the paper label.
http://www.fiatforum.com/donations.php
Stilo Parts For Sale:
Connect Nav+ Map Discs - Wiper Motor (NEW) + Croma Turbo i.e. Badges.
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 12-01-2012   #1533
Thanks for the quick reply man, much apreciated!! thanks for the info too!! i think i will take it to the Fiat deal so the connect it up to the BC!!!
I have the CD changer codes in the small booklet it brings, the only thing is that it just flashes and does not work lol!!
on another note i have heard that inserting a 9.8 version of the ConnectNav+ skips the master code request message? is this true??
Thanks man!!
Old 12-01-2012   #1534
Moderator
Davren's Avatar
Trader Rating: 1
Davren has donated!
A Fiat dealer doesn't "connect it up to the BC", You get the code from a dealer then when you enter the code the CN+ and the BC automatically pair with each other.
If all 5 CDC lights are flashing, it generaly indicates that a CD is jammed in the mechanism or the mechanism is broken or misaligned.
Yes... installing version 9.8 firmware will bypass the need for a code but you may have to reinstal it each time you need to disconnect the battery.
Old 12-01-2012   #1535
Thanks, i could install the 9.8 version even if i have limited access to functions on the CN+? The only thing i can do atm is insert and eject cds as the master code request does not let me "navigate"
The stilo gives me too many elecrical problems man!!
Old 12-01-2012   #1536
dmasterhyde1992 has donated!
Worked perfectly
Cheers,
Dan
dmasterhyde1992 is offline Reply With Quote Quote
Old 12-01-2012   #1537
Quote Originally Posted by dmasterhyde1992 View Post
Worked perfectly
Cheers,
Dan
Hey Dan, have you also been having the same problem?
all the best
Lee
Old 12-01-2012   #1538
Moderator
Davren's Avatar
Trader Rating: 1
Davren has donated!
Quote Originally Posted by Lee800m View Post
Yes... if the master code request message you get is the same as in the picture below, you can still do the update. I did one for someone yesterday.
The update instructions say a few times, "clear any error messages using the "ESCAPE" button". Ignore that for the master code request error message, but procede exactly as described with the rest of the instructions.
Name:	Master Code request .JPG
Old 12-01-2012   #1539
Quote Originally Posted by Davren View Post
Thank you!! your the man!! Ill give it a try later on this afternoon!! But first i got to dismantle my CN+ as i inserted the setup disk last night and now it does not eject!! Any thoughts on why this has happend :/
Its one thing after the other!!
Old 12-01-2012   #1540
Moderator
Davren's Avatar
Trader Rating: 1
Davren has donated!
No... no idea why it happened, but I posted instructions how to remove a stuck CD from a CN+ in post #5 of this thread:
http://www.fiatforum.com/i-c-e/28338...ml#post2870240
Old 12-01-2012   #1541
Hi Dave, Please could you help me, i have a scudo, 03 plate, i took the battery off and the radio is now blocked on connection, it says i need a code... i found a sticker on the side and there is a serial number of C70000002226K... is there a code to unblock or do i need to buy a new radio..:-( Thank you in advance..
Martine85 is offline Reply With Quote Quote
Old 12-01-2012   #1542
Moderator
Davren's Avatar
Trader Rating: 1
Davren has donated!
Quote Originally Posted by Martine85 View Post
Please post all the numbers from the radio including the PU-XXXXX(X) and the other two numbers beginning with C. Then I may be able to get your code.
Old 15-01-2012   #1543
mzhussein has donated!
Hi all,
Put my stilo back to stock, could i trouble you for a radio code?
Serial: M194849
(i think thats all you need no?)
just encase
Fiat Part No:
735374218
Model:
OB
Thanks in advance
mzhussein is offline Reply With Quote Quote
Old 15-01-2012   #1544
Moderator
Davren's Avatar
Trader Rating: 1
Davren has donated!
Quote Originally Posted by mzhussein View Post
Hi all,
Serial: M194849
just encase
Fiat Part No:
735374218
Model:
OB
Thanks in advance
Your code is: 0139
Thanks mzhussein thanked for this post
Old 15-01-2012   #1545
Your code is: 0139
Many thanks
(T) Fiat blaupunkt radio code mattiwillo Punto (Mk2/2b) 13 19-08-2010 17:49
(T) Yet another Radio Code Thread quinlabrat Punto (Mk2/2b) 1 06-12-2009 19:21
(G) Fiat Punto Radio Code Scorpioxx Punto (Mk2/2b) 2 15-08-2009 11:13
(G) Fiat Multipla Radio Code Badfeelingtoo Multipla 2 06-03-2009 19:37
