The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 14-08-2006   #1
Brava 1.6 ELX
reaper1988's Avatar
Trader Rating: (0)
reaper1988 has donated! United Kingdom
Power Wire?
Ok i have a 1000 amp and 1000watt wireing kit for it. Im getting another 1600 watt amp. Do i need to get another power cable thats thicker and split it or will the 1000watt wireing kit be ok to split?
reaper1988 is offline
Old 14-08-2006   #2
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
Re: Power Wire?
What gauge is the cable and what are the current draw of the amps?
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 14-08-2006   #3
Brava 1.6 ELX
reaper1988's Avatar
Trader Rating: (0)
Re: Power Wire?
Old 14-08-2006   #4
kritip's Avatar
Trader Rating: (3)
kritip has donated! United Kingdom
Re: Power Wire?
Those powers are peak powers, but tbh I would get another cable and run each amp seperatley, or upgrade the cable to one big cable.
I don't like the way wiring kits are aimed at amp outpit really, kinda stupid. It should be based on the power consumption of the amp and not what it can put out (too many variable, PMPO, RMS, ohms etc).
I wouldn't like to run both off that cable on its own iif i was wiring them up though.
Kristian
Black Seicento Sporting mk2
1242cc 16V conversion finished and removed!
Megasquirt installed, a constant evolution
1368cc and 6 speed running great now
My Members Motors thread
kritip is offline
Old 15-08-2006   #5
Formerly mog1571
Luke M's Avatar
Trader Rating: (2)
Luke M has donated! United Kingdom
Re: Power Wire?
if your running 2 amps off one cable i would put in a fused splitter box and choose your fuses carefully! and make sure the wire is rated high enough for the combined current drawn plus a little extra
Previous 2005-2007 - 2001 Capri blue seicento SX
Current 57 plate GP active sport, action red, Sporting front fogs, JBL Sub and amp.
Luke M is offline
Old 15-08-2006   #6
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
Re: Power Wire?
You need extra cabling. I'm not sure if 8 awg would cut it for the 4 channel amp or whether you need 4 awg. What are the fuse ratings of the amps, then I can tell you straight away if the cabling's suitable
chaos is offline
Old 15-08-2006   #7
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
Re: Power Wire?
2600 peak, lets say 1300rms, I'd get some 0 guage in there myself.
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
Chord Epic speaker cable and Anthem RCA leads.
paulbfd is offline
Old 15-08-2006   #8
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
Re: Power Wire?
It's more like 290WRMS Paul 4x35 + 2x75.
chaos is offline
Old 15-08-2006   #9
paulbfd's Avatar
Trader Rating: (0)
Re: Power Wire?
Being a bit of a slacker I didn't notice the links posted above.
All I can say, is WTF? Where the hell did they pull 1000 & 1600 figures from? Their arse more than likely, silly sods.
Black 100HP
paulbfd is offline
Old 16-08-2006   #10
Brava 1.6 ELX
reaper1988's Avatar
Trader Rating: (0)
Re: Power Wire?
The peak powers of the amps dont seem to go with the RMS output....is this true....should i have a look at getting a different 1600w amp as i havnt bought it yet.
Do i need to look for a higher RMS output?
Old 16-08-2006   #11
Brava 1.6 ELX
reaper1988's Avatar
Trader Rating: (0)
Re: Power Wire?
Would i be better off buying this:
http://www.caraudiodesign.co.uk/prod...nel-amplifiers
instead of the 1600w i was getting at the top of the post.
Old 16-08-2006   #12
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
Re: Power Wire?
Hold your horses a minute
What's your budget and what is the amp going to be used for?
chaos is offline
Old 16-08-2006   #13
Brava 1.6 ELX
reaper1988's Avatar
Trader Rating: (0)
Re: Power Wire?
Sorry. Its going to power 2 12" (1 800watt and 1 750watt) Subs and my budget is £60.
Old 17-08-2006   #14
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
Re: Power Wire?
What subs exactly?
chaos is offline
Old 17-08-2006   #15
Brava 1.6 ELX
reaper1988's Avatar
Trader Rating: (0)
Re: Power Wire?
I got them second hand so i dont know what makes. Although i have found the pictures of them.
XPlod - http://cgi.ebay.com/2-12-SONY-EXPLOD...QQcmdZViewItem
JVC - http://cgi.ebay.co.uk/JVC-Car-Bass-S...QQcmdZViewItem
Urgent! HU HELP!! alainax I.C.E 10 03-10-2005 19:33
(G) Need Power TrackdayCinq Cinquecento / Seicento 29 10-12-2004 14:49
(T) Powerflow - More Power? mckcrich Cinquecento / Seicento 9 04-12-2004 17:55
How To Wire Amp - Punto jdunderhill I.C.E 0 06-03-2004 21:15
(T) Seicento Power Steering? dawozere Cinquecento / Seicento 7 27-02-2004 16:30
