The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 23-12-2003   #1
Trader Rating: (0)
Punto Built in Sub
Is there a way to connect the standard punto sub into a normal (Sony) hu, where do i connect the wires (they are in a block but do come out.
Ta
James Bone is offline
Old 23-12-2003   #2
Trader Rating: (0)
Or how do i connect another sub (looking at a 10" boxed one).
Old 23-12-2003   #3
thefishdude's Avatar
Trader Rating: (0)
thefishdude has donated! United Kingdom
the standard fiat sub is soooo easy to conect in fact you dont have to do anything lol.
basically the fiat sub recieves power from the auto antenna wire that comes from fiat stereo pin 3 as i said in your other thread.
providing the location of the auto antenna pin is same on your new steree it will just work. oh and providing you havent moved the yellow wire like you said in other post.
when you say the wires are in a block if you mean that multi-colored block reg green yellow i think. then you do not need to connect any of them wires up to your new steroe. that block is there so that the on boacrd computer can check if you have inputted the stereo code into teh radio. so if you have taken the fiat radio out you do not need them wires just leave the block lose i did.
thefishdude is offline
Old 23-12-2003   #4
Trader Rating: (0)
Ah brillo, will have to sit by it tomorrow and see if it is on (never really notcied tbh). To fit a new one would i just steal the wires from the fiat one?
Thanks for your help, ill let you know tomorrow if both things work.
Edit: yeah i did mean that multi coloured block.
Old 23-12-2003   #5
Trader Rating: (0)
dont know about fitting a new sub as i have never done that.
few months a go i changed my head unit and had probs so had to look up all the wiring for the car that is how i know about the fiat fitted equipemnt. have never fitted any after markets subs before.
hope you get all your problems sorted. i will look for ya post i wont be around untill tomorrow evening though.
Old 23-12-2003   #6
Trader Rating: (0)
OK, will give it a test. Thanks so much, finally a MK2 owner having the same probs!!
Old 23-12-2003   #7
Trader Rating: (0)
Daft question time....
..how does the Built in sub recieve its signal if its only the auto antenna that sends it the on / off signal.:I
Old 23-12-2003   #8
Trader Rating: (0)
well like i said the auto antena prvides it with power but i belive the actual signal for making teh sond comes from the normal speaker outs on back of the radio these pass through a few blocks on teh wiring diagram i am looking at so i assume some thing in there sorts out the low signals for the sub and then passes them down a seperate wire to the back along with the other wires for the rear speakers.
vB code is On
Buying a Punto from auction! SpunkyM Punto 11 21-12-2007 20:19
Punto Sporting (New Shape) -Too Many Problems Dee Punto 18 18-10-2007 11:10
16 or 17 inch wheels for Punto HGT / Abarth punto_power_nr_1 Lets Talk FIAT 9 25-06-2006 16:01
My PUNTO is dead (I think) I crashed it!!!! J_poshpromo Punto 13 26-11-2004 09:32
Fiat recalls - Punto [1] roby76it Lets Talk FIAT 0 14-04-2003 01:50
