| Sub Under Punto Driver Seat Hi Can anyone recommend a decent subwoofer to mount under a Punto Drivers seat? It doesn't have to be a large sub, just something that is going to produce a bit of a kick I have been reading about subs needing a certain volume of litres in a box to get best performance but obviously I have space restrictions An ideal solution for me would be a sub mounted in a box that fits neatly under the seat and has velcro on the bottom to sstop it sliding powered by my amp Thank in advance Jamie
| ate too much | dont know if the punto has the spare in the boot,but pioneer did/do a sub that fits in the spare wheel well.any good for ya[?] The Fiat Cinquecento Fun While It Runs
| | #3 | ||
| How much you wanting to spend? A Crystal CMP-8 is one of the most rated subs out at the moment. Its and 8 which will work best in a very small box. It has been tested and ICE heads all over the world would swear blind that its a 15"er before seeing it. It really is that good. Matt __________________________________________________ 54 BHP of pure italian muscle
| | #4 | ||
| Cheers custard boy and sando, yes i'm looking for a sub specifically under the drivers seat because you can really feel the bass, you can get the same effect of a much powerful system for a little cheaper, i'd go up to £200 for a decent sub under the seat,a crystal 8 inch sounds perfect, I would prob make my own box and cover it in carpet, I wonder if it has to be of a certain volume to get the best performance from the sub, I bet there isn't much space to work with under the seat I have a sub built into my chair indoors rigged up to PC and it really enhances the music!! its only a crappy old sub but sounds so much better when mounted there and thought why not try it in the car but buy a better sub and look into building a box myself Thanks for your help
| | #5 | ||
| http://www.caraudiodirect.co.uk/default.php?cPath=17_18_286&osCsid=f8e289a978d238d 0653d07f0ab275853 A page of 8" subs http://www.caraudiodirect.co.uk/product_info.php?products_id=2730&osCsid=f8e289a97 8d238d0653d07f0ab275853 for an RE 8 (very highly rated and only £59.99 http://www.caraudiodirect.co.uk/product_info.php?products_id=2932&osCsid=f8e289a97 8d238d0653d07f0ab275853 Crystal COMP8 also www.talkaudio.co.uk for an ICE forum, ask the guys on there about making a small box and the best sized box for a COMP8. Whats wrong with the boot anyway? Matt __________________________________________________ 54 BHP of pure italian muscle
| | #6 | ||
| http://www.caraudiodirect.co.uk/product_info.php?products_id=2262&osCsid=f8e289a97 8d238d0653d07f0ab275853 :) Another day...another problem...
| | #7 | ||
| Fat pigeon... APPLE! | Infinity used to (still might) make the BassLink, it's a small but pretty meaty self-contained active sub unit. Designed to be stuffed under seats where it can be heard and not seen! No idea what it costs. ------/F/I/A/T/------ Fart In A Tin
| | #8 | ||
| Fat pigeon... APPLE! | Just took a look on MCS,, here ya go... INFINITY Basslink 10INCH Subwoofer, 10INCH passive radiator and 200 watt RMS Class D amplifier. Speaker and line level inputs. Fixed 2nd order high pass filter. Continuously variable electronic low pass filter. Variable input sensitivity. Accepts up to 4 channels of input. Mount vertically or horizontally . £169.99 http://www.mcs-direct.co.uk/acatalog/MCS_DIRECT_CLEARANCE_SPECIALS_129.html ------/F/I/A/T/------ Fart In A Tin
| | #9 | |||||
| | #10 | ||
| Cheers everyone, some quality ideas on here for getting the right sub, im definately going to build this after xmas, I think the plan will be to get a 8" sub that can fit in a small ported box. Get some mdf and some carpet and some speaker terminals, some velcro to hold it in place so it doesn't slide and it should sound superb The boot is ok for subs but I always used to put the sub behind my seat so you can really feel when the bass kicks, this will be exactly the same thing but under the seat, hopefully it will be discrete enough to hide from thieves Thanks Jamie
| | #11 | ||
| Fat pigeon... APPLE! | Really, Sando? I always thought they were a small item! Hmmmm, I must've been thinking of another sub. Some company definitely makes a similar thing that goes under seats, can't remember who it was if not Infinity. Anyway, good luck with your sub box Jamie. I built a big sealed box for a 12" Pioneer woofer in the back of my Punto, took a while but worth the effort. Useful stuff to know (most of which I found out through my own misfortune!): Measure up properly, use a decent jigsaw to cut the wood (cheap ones make a right mess), watch for mdf splitting when you put screws in, and use plenty of silicon sealant!!! ------/F/I/A/T/------ Fart In A Tin
| | #12 | ||
| Good advice, remember to leave the silicone sealant for about 4-5 days before putting the sub in though...it will need time to go off, otherwise the vapours start to corrode the subwoofer cone material. Matt __________________________________________________ 54 BHP of pure italian muscle
| | #13 | |||||
| NobodyBlamesTheHappyGuy:D |
Use 19 mm MDF. BEFORE putting in screws, apply glue to edges to be fitted together, then drill a small hole through both. Drill with a larger size through the first MDF - this should be the size of the screw, hence the screw should pass through the first MDF and stop in the second where the smaller hole is. But before inserting the screw, use a very large size to drill a lowering for the screws head. And yes use sealant. Do NOT use the latest Black & Decker jigsaws. Those with snap-on blades. The blade snaps out off position and makes the saw pull left or right, making a really crappy edge, not suitable for anything actually. This makes a perfect box. :D Morten. Abarth alloys. Inter Alloy lowering. Phoenix Gold & Kenwood audio. Abarth steering wheel. Insane Dalmatian door and seat refurnishing Projects: K&N induction kit, racing seats, exhaust, window tinting.
| Punto Sporting (New Shape) -Too Many Problems | Dee | Punto | 18 | 18-10-2007 11:10 |
| 16 or 17 inch wheels for Punto HGT / Abarth | punto_power_nr_1 | Lets Talk FIAT | 9 | 25-06-2006 16:01 |
| I have loads of Fiat interior cloths!!! | alfanige | Lets Talk FIAT | 3 | 16-02-2004 16:36 |
| Cinq Driver Seat & Spoiler | Danny Evans | Parts Wanted | 0 | 27-07-2003 02:19 |
| Fiat recalls - Punto [1] | roby76it | Lets Talk FIAT | 0 | 14-04-2003 01:50 |
