| Banned | Wiring...? Can anyone tell me the correct way of wiring under the carpet correctly and ect .. Also what bits i will need ... i saw this on ebay http://cgi.ebay.co.uk/3000w-Amplifie...QQcmdZViewItem I got 3000 watt amps ( 2x) Subs 1600(2x) 6x9s 2000watts (2x)
| Re: Wiring...? Run power down one side (the side the battery is on), RCA leads down the middle and speaker wires down the other. You'll need 0 gauge power cable, that Ebay one is not upto the job. Autoleads do a kit called the PC4-28, it's 0 gauge cable + 4 gauge, fuse holder, distribution block and ground terminal. Can be had for around £50 and will run 2 amplifiers. You'll just need some RCA leads and speaker wire.
__________________ Black 100HP Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller. Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier. Chord Epic speaker cable and Anthem RCA leads. | |||
| Speaker wiring confusing me! | phil_harry | I.C.E | 4 | 21-12-2005 17:07 |
| Punto factory sub wiring! | project-cinqy | I.C.E | 3 | 25-07-2005 00:34 |
| Seidici 2.0 dashboard wiring | luisgois | Tipo | 1 | 24-07-2005 20:37 |
| | cjboss | Cinquecento / Seicento | 3 | 20-03-2005 00:14 |
| Rear speaker wiring? | ScottieCinq | I.C.E | 3 | 25-05-2004 21:02 |
