The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 16-01-2006   #1
compensation needed
crazydave's Avatar
Trader Rating: (0)
crazydave has donated! United Kingdom
Components
Hey, dunno if the title has put some of you off but, i bought an alpine mrp t220 amp (250watt max) powering some 6x9's in my mk2b punto they sound much clearer now. However i have some infinity reference 16.5 coaxial door speakers which i have just realised will not keep up to the 6x9's as they run off the head unit. Rather than getting another amp for the door speakers i have been looking at the idea of components, does any body know a guide on the forum or web page giving step by step guide to fitting components, or what they feel they would do instead?
Dave
crazydave is offline
Old 16-01-2006   #2
compensation needed
crazydave's Avatar
Trader Rating: (0)
Re: Components
I have seen these components but dunno if they would fit in the space http://caraudiosecurity.com/shop/pro...s_id/3522.html any ideas
Old 16-01-2006   #3
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
Re: Components
I'm not sure whether they'd fit into a Punto - that really is a question for the Punto guys to answer, but I got a feeling they would fit
I feel just fitting components alone will not get the results you're after. I would buy and amp the components. And personally, I would ditch the 6x9s, but each to their own
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 16-01-2006   #4
compensation needed
crazydave's Avatar
Trader Rating: (0)
Re: Components
cheers, il see what happens and if anyone else can help. thanks chaos il let u know what i do, im still looking for a guide on wiring components
Old 16-01-2006   #5
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
Re: Components
Wiring them in is child's play Dead simple
chaos is offline
Old 16-01-2006   #6
Simplify & Add Lightness
H2DaE's Avatar
Trader Rating: (1)
H2DaE has donated! United Kingdom
Re: Components
They will fit in the doors, but only with an adaptor. I know this, as these are the same speakers I have. Well, mine are the type S, but the only difference I can see is 20W RMS of power. They are awesome speakers, but I would recommend amping them up to get their full potential. If you need a hand installing them drop me a PM
Mk2 Punto 1.9JTD - GSR/ChippedUK tuned - 118bhp/187lb/ft
Want a set of Sporting Alloys?
www.SpiritoDiPunto.com - For technical talk and all things Punto!
H2DaE is offline
Old 17-01-2006   #7
compensation needed
crazydave's Avatar
Trader Rating: (0)
Re: Components
Thanks H2Dae, if i was to run another amp this would draw more current from my 425amp battery im already powering 3 amps so could be a second battery required i think. would they be ok to start without an amp at first or would it not sound as good
Old 17-01-2006   #8
Trader Rating: (0)
marky.b has donated!
Re: Components
Try running the components off the amp and power the 6x9 from the h/u
DB Drag Super Street 1-2 UK Champion
Proudly sponsered by Utopia Audio
marky.b is offline
Old 17-01-2006   #9
compensation needed
crazydave's Avatar
Trader Rating: (0)
Re: Components
That sounds a pretty decent idea, but before my 6x9s were amped sounded fine and the door speakers were starting to distort so would the 6x9's now distort instead of the components?
Old 17-01-2006   #10
The Older Modder
steve1219's Avatar
Trader Rating: (2)
steve1219 has donated! United Kingdom
Re: Components
I am powering 2 x mono blocks, and 2 x 4ch amps and other bits and bobs on a standard punto battery with very little trouble.
I do carry a stand bye battery behind the passenger seat just in case though
Never drive faster than your Guardian Angel can fly!!
You can only be young ONCE, but you can be IMMATURE for EVER!!
Show you car with Fiat Forum check out the EVENTS section for a show that fits your style
steve1219 is offline
Old 17-01-2006   #11
compensation needed
crazydave's Avatar
Trader Rating: (0)
Re: Components
as a second battery? or ready to replace the old one?
Old 17-01-2006   #12
The Older Modder
steve1219's Avatar
Trader Rating: (2)
Re: Components
Just to jump start the car if the other dies,still got to get around to set it up on trickle charge so I will have 2 permanently in the car. Not that I have had to use it for that yet as long as I only use the system when the engine is going do not seem to have to much of a problem.
Steve
Old 17-01-2006   #13
T.E.D.
Trader Rating: (1)
T.E.D. Jordan has donated! United Kingdom
Re: Components
I am have the infinity reference 17cm component speaker set coming soon, orderd a set off of ebay the other night - they are very very good, and i have been recommended to amp them by chaos as well as other with the same - you have chosen well!
Total Engineering Developments
T.E.D. Jordan is offline
Old 17-01-2006   #14
H2DaE's Avatar
Trader Rating: (1)
Re: Components
I can't recommend amping up components enough now that i've done mine. Make sure your amp has a high pass filter (i assume most do) and they will be the perfect compliment to the sub/s you have. If it was my car I'd do away with the 6x9's altogether (I know Chaos will agree with me ) but it's all down to your personal preference
*Edit* just seen what amp you have for your 6x9's, its the same as mine, superb amp
H2DaE is offline
Old 17-01-2006   #15
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
Re: Components
Oh yeah
chaos is offline
components, herts and frequency 99sei I.C.E 2 07-12-2005 15:42
Pioneer components + install ideas Luke I.C.E 11 08-11-2005 11:25
(T) Center and rear exhaust components geom Uno 3 02-05-2005 21:54
Quick components question please.... peterp I.C.E 3 07-02-2005 11:05
components in the front of a cinq? arc I.C.E 16 27-12-2004 00:21
