The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 15-01-2006   #1
T.E.D.
Trader Rating: (1)
T.E.D. Jordan has donated! United Kingdom
New purchases....
Well yesterday i went and bought the 2 12's i've wanted for ages for £100 brand new from halfrauds (i know but they were doing a great deal) for £100 together. I bought 2 Infinity reference 1240w subs. They run at 300watt RMS, and although i know this isnt that great for 12's boy do they perform well and look gorgeous. I was hoping somebody could tell me amp to get as im wanting to fit in with the colour scheme as well. Im wanting something mostly dark grey/black or silver. I wuld appreciate if someone like chaos would post some good info up. I have around a £150 budget for this amp, but i am also getting a 10" version of the same and the 17cm Infinity reference componets kit in the near future. ANY help would be appreciated. The specs are below the pics:
Single 4-ohm voice coil
Sensitivity 93db
Freq. Response - 23hz-400hz
Power Handling 300w-1,200w
Peak power handling 1,200w
ANy help pr advice would be appreciated, thankyou
Total Engineering Developments
T.E.D. Jordan is offline
Old 15-01-2006   #2
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
Re: New purchases....
You want an amp that'll put out 600WRMS @ 2ohm, with the subs wired in parallel, as shown here
By wiring the subs in parallel, the amp would see 2 ohm impedance
Potential amps:
http://www.caraudiodirect.co.uk/prod...426734753d9bd0
580WRMS @ 2ohm, £150
If you can stretch the budget a bit further:
650WRMS @ 2ohm, £180
IMO, the second one would probably suit you best - it is better to slightly overpower the speakers than the amp, and it'd fit into your design better.
Have you considered using a false floor and totally hiding the amp? You would need to use forced cooling, but that isn't a big problem
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 15-01-2006   #3
T.E.D.
Trader Rating: (1)
Thanks chaos
I hadnt ruled out sinking the sub into the floor and using 2 or three PC fans, but i was hoping to display it, although this is wishful thinking as i have a MK1 punto, 2 12's a 10 and an Amp is very much pushing it especailly as i am using the correct air space per box for each one,
I do like the look of that blaupunkt one, although id say with all these options i would need another amp to amp my component set and 10" sub - maybe i shoudl look at the cheap and tacky amps ?
Old 15-01-2006   #4
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
TBH I don't know how 1 10 with 2 12s would sound. If it was me, I would stick to just the 2 12s. What sort of comps are we talking about here, and a budget for the amp? You might be able to pick up a really good amp for a bargain price - you don't necesarily have to buy new
chaos is offline
Old 15-01-2006   #5
T.E.D.
Trader Rating: (1)
Well something like these components:
http://motors.search.ebay.co.uk/Infi...25QQsacatZ3270
or
http://cgi.ebay.co.uk/INFINITY-6510c...ayphotohosting
Propably the 2nd link as first are ridiculously priced IMO.
Like i said, £150 for the Amp i can stretch to, and another amp if neccesary. I would consider another amp, there is a place near me that does perfectly re-conditoned ones, always flawless finishes too which i like
Old 15-01-2006   #6
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
or
You're going to have to have 2 amps - you wouldn't get an amp that would run both subs together with a set of comps.
What about the 10" sub? Are you still thinking about going for it, or are you sticking to 2 12s?
chaos is offline
Old 15-01-2006   #7
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
There's this
http://caraudiosecurity.com/shop/pro...s_id/2910.html or http://www.caraudiodirect.co.uk/prod...380fabb4ebe098, £80, 97WRMS @ 4ohm x 2
TBH I think you may be looking at second hand here
chaos is offline
Old 15-01-2006   #8
T.E.D.
Trader Rating: (1)
Im afriad i really will have to stick with the 10 as well as i have heard the tri set-up in another car and it kept up quicker which sunded-in the 12's, hard to explain but it was impressive.
I think it would be best I deffinatly aim at a 2nd hand amp, and maybe get 2 of the same. Run the 2 12's off one and the 10 with the component set off another. The component set is going in the rear shelf as i do not like the whole popular 6x9's type thing - i have fitted so many into cars i am bored of them, yes alot of them give good sound but - meh! I dont like very much!
I dont think theres an infinity amp that would run the 12's on their own for under £150 either
Old 15-01-2006   #9
T.E.D.
Trader Rating: (1)
Just saw this, that would run my 10" when i get it and my component set wouldnt it?
http://cgi.ebay.co.uk/JBL-GTO-75-4-a...QQcmdZViewItem
Old 15-01-2006   #10
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
What 10" sub have you got?
That JBL would run the comps fairly tidily An ideal sub would be a 250WRMS one
chaos is offline
Old 15-01-2006   #11
T.E.D.
Trader Rating: (1)
I think i will get that amp. and use it purely for the components and get an 800w RMS 4 Channel that will run my 2 infinity 12"'s and the 1 10" i am planning to get - this one: http://www.sonicelectronix.com/item_5778.html
Do you think that would work?
You've been a massive help so far thankyou
Old 16-01-2006   #12
Forum moderator
Helz's Avatar
Trader Rating: (3)
Helz has donated! United Kingdom
Sounds like it will be interesting, can't wait to hear you bouncing round town!
Helz is offline
Old 16-01-2006   #13
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
I would have the JBL 4 channel powering the comps and the 10" sub, with the Blaupunkt amp powering the 2 12s TBH
The link is for your 10" Infinity sub and not of an amp
chaos is offline
Old 16-01-2006   #14
T.E.D.
Trader Rating: (1)
Sorry i plan to do as you have said, you've been a great help, and i just need to know one more thing, will the 10" andcompent sets be alright with what the amp is powering ohm wise? thats the only real thing i struggle with
Old 16-01-2006   #15
T.E.D.
Trader Rating: (1)
lol Thankyou I'll turn it up as i pass your work and you can roll ur eyes n think im sad!!!!
Should sound good.
If i get it going!
