| ermm right then i have got my self 2 Pioneer TS-W3004SPL 12" subs and i dont no wot amp 2 get i got told by bass junkies 2 get a JL Audio JL1000/1. the subs r 1000rms each and the amp is a 1000rms they said it would still get 1000rms 2 each sub will it
| | #2 | |||||
| Re: ermm
| | #3 | ||
| Ah. Not good... | Re: ermm Its a DVC sub isn't it? If you wired the subs so that the amp sees 2 ohm, and have a 2000WRMS @ 2 ohm amp, that would be sufficient, I think. It is a tad late, but I'll go and double check. The JL amp, from what I can find, will put out 1000WRMS at either 2 or 4 ohm. Therefore, it would be a sufficent amp to power 1 TS-W3004SPL, but not 2. Last edited by chaos; 15-01-2006 at 01:02. | ||
| | #4 | |||||||||
| Re: ermm
It will be ample for those subs.
__________________ http://www.fiatforum.com/gallery/dat...new-sig-an.gif
| | #5 | |||
I think I made a mistake or 2 in my previous post.Going by this - http://www.rockfordfosgate.com/rftec...x=25&image.y=4 you can make the two subs show a 4 ohm load to the amp. You would want a 2000W RMS amp @ 4 ohm, I think. You could use it as a D2 configuration to make the amp see a 2 ohm load and have a 2000WRMS @ 2 ohm amp. I hope that's right anyway. Chris, from what I can gather from the amp specs, it will run at 1000WRMS from 1.5 ohm to 4 ohm. The voltages change though from 11V to 14.4V, i.e the impedance changes with input voltage and not with wattage. 2000 posts! Last edited by chaos; 15-01-2006 at 02:00. | |||
| | #6 | |||||
| Re: ermm
How do you get 2000W from an amp that only pushes out 1000w?
| | #7 | |||
| The Older Modder | Re: ermm
no matter how you configered the subs to get 1000RMS to both subs.Stve
__________________ Never drive faster than your Guardian Angel can fly!! You can only be young ONCE, but you can be IMMATURE for EVER!! | |||
| | #8 | ||
| Re: ermm I did have amps for sale that would have 3000w at 1ohm but have just sold all eight !! If your looking at that sort of power then look at the utopia discount thread and give the owner of utopia a call. Powerbass have just launched there new 2000w amp at the ces show in the states and is well worth a look as I believe it will be very cheap for the power + you can use the 20% discount. Always best to ask for advise when dealing with bass monkeys as they tend to sell you what will give them the biggest profit margin, not what is best suited to your system imo.
__________________ DB Drag Super Street 1-2 UK Champion Proudly sponsered by Utopia Audio | |||
| | #9 | ||
| Re: ermm some pictures of the amp can be seen here http://www.utopiaaudio.co.uk/forum/viewtopic.php?t=120 about 10 pictures down
| | #10 | |||
| | #11 | |||
. I was so knackered last night, I couldn't think straight | |||
| | #12 | |||
| Re: ermm
__________________ DB Drag Super Street 1-2 UK Champion Proudly sponsered by Utopia Audio | ||||
| | jimmy | Cinquecento / Seicento | 2 | 11-10-2003 07:21 |
