The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 10-12-2005   #1
Trader Rating: (0)
Noise Supressors
Can noise supressors be used between my dvd player in the boot, and my head-unit aux-in? would this sort out my interference problem? I do not have any amps, just the basic line-in, from my dvd player.
Cheers,
Tom
tomweise is offline
Old 10-12-2005   #2
bozzy's Avatar
Trader Rating: (3)
bozzy has donated! United Kingdom
Re: Noise Supressors
Can you firstly explain your interference problem. Is it when the tuner is on or CD? does it get louder with the revs or what. Any info would help here but I don't have faith in surpressors. Find the route cause first and nail that. What car/gear?
Did you earth the DVD at the boot end or head unit end?
bozzy is offline
Old 10-12-2005   #3
Trader Rating: (0)
It's whenever the DVD player is on. It doesn't happen through the CD or Radio. There is a noise that increases with the Revs, but this is not noticible untill you turn the Head-Unit up quite loud.
It's a MK2 punto.
The only earth i know of, is the fact it is earthed at the head-unit end..through the ISO cable. It's a SONY Picot1 dvd player, so i don't really know how to earth it. It is earthed through the plug?
Cheers..thanks for helping...annoying problem this.
Tom
tomweise is offline
Old 10-12-2005   #4
bozzy's Avatar
Trader Rating: (3)
The aux cable connecting the DVD plaer to the Head Unit, did it have an earth cable at either end, usually the DVD end? It must be earthed in some way.
bozzy is offline
Old 10-12-2005   #5
Trader Rating: (0)
the only two earths i know it had, is the head-unit is earthed through the ISO, as i said above. and the dvd player is only earthed through the electrical plug, which i had plugged in an extension lead tonight, and it hummed then. but it usually hums aswell, when working through the invertor, but this is not earthed, so the dvd player will not be earthed through the plug then.
Cheers,
Tom
tomweise is offline
Old 10-12-2005   #6
Trader Rating: (0)
how about a ground loop isolator?
tomweise is offline
Old 12-12-2005   #7
Trader Rating: (0)
I would suggest a screened cable from your dvd player to your head unit. Grounding of the screen should be done near to the point where your head unit is grounded. This will lower the chance of ground loops, as its more likely the two will then be at the same electrical potential. Hope this helps.
FiAt_PuNtO is offline
(T) continuous clicking noise wiper motor? HELP nickphonics18 Punto 2 13-02-2005 15:14
(T) Rattley/knocky noise simon1978 Punto 2 31-01-2005 23:22
(T) Jingling noise from rear HornetUK Stilo 4 05-09-2004 20:09
Noise from Air Vent/Turbo Lou Ulysse 7 07-06-2004 04:27
(T) Rear noise when moving off Paddy_Punto Punto 2 25-12-2003 18:42
