The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 10-11-2003   #1
Moderation in Moderation
GhostWKD's Avatar
Trader Rating: (0)
GhostWKD has donated! United Kingdom
Headunit wiring
currently headunit wont turn off when ignition is turned off, and can be turned on without ignition, is there anyway i can rewire this? (i know there surely must be just want reassurance before i start messing about :p)
Cinquecento Sporting,
and yes it is indeed Broom Yellow \o/
GhostWKD is offline
Old 10-11-2003   #2
Banned
Bushboy's Avatar
Trader Rating: (2)
Bushboy has donated! United Kingdom
dunno about the cinq but on the uno you cna just wire the remote cable from the radio upto the ignition wire that powers everything that turns on and off with the key. That would work whist allowing your radio to keep its stations stored etc.
i expect this can be done easily in all cars... you will just have to find the ignition cable thing (if thats what its called)
My Lovely Uno
Bushboy is offline
Old 15-11-2003   #3
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Hei.
There should be two power / live (+) wires. They are usually red and yellow from the headunit. Different cars have different layout, and sometimes these two are "hotwired" into each other. This gives always power to the radio. You should separate these (or make the correct connections) so there is one continous power (yellow I think) going from the battery to the radio. This is for keeping the clock settings etc. on your head unit. The other (propably red - I might be mixing these two colors right now) should come from the ignition, so the radio power is cut off when you switch the engine off.
There should be three wires under the dash that are of interest. Two + and one - (ground). Try these. You may blow a fuse or two, but very little damage is likely to be done. That's what the fuses are there for... Ground is almost always black, but beware that the Italian who made the wirings after a glass too much 'vino rosso' may have messed up the colors.
Morty Mort is offline
Old 20-11-2003   #4
Trader Rating: (0)
Yes it can be done, Do you still have your user manual? In my manual for my Brava it gives a brief description of what needs to be done. Look in there if you have it!
Tim
badass_tim is offline
Old 21-11-2003   #5
polecat's Avatar
Trader Rating: (0)
polecat has donated! United Kingdom
Sorry don't know the history behind this question but it might just be a user set-up option. My built in comes with the options of switching on/off with the key and the on/off switch or just the on/off switch. I just hold in the mute button for a few seconds to switch between options.
85% of Marea HLX drivers have speeding tickets.... lol they'll have to catch me first.
polecat is offline
vB code is On
upgraded headunit jay316 I.C.E 3 07-01-2006 19:16
wiring fault AAAAH! cjboss Cinq/Sei > Technical 3 19-03-2005 23:14
Which headunit? GhostWKD I.C.E 13 01-06-2004 19:58
Rear speaker wiring? ScottieCinq I.C.E 3 25-05-2004 20:02
Wiring Harness / 93 Cinq (Sorted now) goldflame Cinq/Sei > Styling 7 22-04-2004 16:36
