I have Fiat Bravo '07 1.9 Multijet 16V, but that manual on
multiecuscan page is quite confusing for this type of car?
Thanx
Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9, 2.4) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KLELMOBDKey
Bosch ABS 8 |INFO|DTC|DTC EX|PRM|ACT| KL 1ELM 1OBDKey 1 A1
Bosch ABS 8 ASR |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL 1ELM 1OBDKey 1 A1
Bosch ABS 8 VDC |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL 1ELM 1OBDKey 1 A1
CONTINENTAL Airbag (PROXI) |INFO|DTC|DTC EX|PRM| ELMOBDKey
SIEMENS MY06 Airbag |INFO|DTC|DTC EX|PRM|ACT| ELMOBDKey
TRW Electric Power Steering (3) |INFO|DTC|PRM|ADJ| KL 9ELM 9OBDKey 9 A1
Service Interval Reset |INFO|ADJ| ELMOBDKey
Connect (NAV) Marelli |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
Convergence Lauberhorn C1 (Blue&Me Nav) |INFO|DTC| ELMOBDKey
Convergence Marelli/Microsoft (Blue&Me) |INFO|DTC| ELMOBDKey
Convergence Marelli/Microsoft C3 (Blue&Me Nav) |INFO|DTC| ELMOBDKey
Instrument Panel Marelli |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
Radio Nav Marelli |INFO|DTC|PRM|ACT| ELMOBDKey
Body Computer Marelli (198) |INFO|DTC|PRM|ACT|ADJ| ELMOBDKey
CAN Info |INFO| ELMOBDKey
CAN Monitor / Vehicle Settings |DTC|PRM|ADJ|
CAN Setup / PROXI Alignment Procedure |INFO|ADJ| ELMOBDKey
Marelli climate control |INFO|DTC|DTC EX|PRM|ACT|ADJ| ELMOBDKey
Litronic XENON headlamp (left) |INFO|DTC|PRM|ACT|ADJ| KL 12ELM 12OBDKey 12 A1
Litronic XENON headlamp (right) |INFO|DTC|PRM|ACT| KL 12ELM 12OBDKey 12 A1
Driver's Seat LEAR |INFO|DTC| ELMOBDKey
Parking Control BOSCH |INFO|DTC|PRM|ADJ| ELMOBDKey
Passenger's Seat LEAR |INFO|DTC| ELMOBDKey
Tire Pressure Control (TPMS) TRW |INFO|DTC|DTC EX|PRM|ACT|ADJ| A4
EVERY line has ELM OBDKey,
so an ELM is the better cable type,
there are some KL1, 9, 12 ,etc
so there are SOME elements your VAGCOM KKL cable SHOULD connect to
are you using the coloured adaptor leads..??
Charlie
