Running Amp Power Cable to Engine - 2009 Bravo 2.0
North Wales
Hi everyone :)
I want to install a sub in my Bravo but just can't find a way to get the power cable from the battery into inside the car....
I've got the 2.0 so engine is pretty cramped.
Do any of you know how to do it???
Really want to get it installed!
I did this in my '08 1,9 Mjet. Had to run the power wire from battery down the inside wheel house and into the cabin through one of the rubber grommet in the front door opening. The wire was (barely) visible when opening the door, and the wheel arch plastic cover had to be removed when running the wire.
If I were to do it again, I would drill a hole in the firewall and use a watertight grommet.
