Punto blaupunkt
Punto blaupunkt
rptavares
Manchester
This is my first post in this great forum, congratulations to you all!!!
I just bought a Fiat punto 1.2 elx from 2001, the car have a blaupunkt cassette player and 4 Speakers + 2 Tweeters + 1 Subwoofer all original from fiat. The problem is that the radio only deliveries sound to the front speakers, and I don´t know how to setup the radio to deliver to the rest of the speakers!!!
I dont have the radio manual, so I'm unable to do this whithout your help.
Thanks to both.
But when I press the Audio button, the only option is bass, treb and balance!!!
The other thing is that every time I shut-down the car the radio wont shut-off!!!
Are there any "secret" menus in this unit??
more then likely the person who installed this headunit hard wired it and for got to hook it up to the ignition best way to find this out is to wip hte head unit out and have alook if the wires have benn choped or been put inwith iso plugs
Nothing happens if I press and hold the "audio" button!! And if I press the diferent buttons nothing happens!!! I even have pressed two buttons at the same time and nothing!!
Hello. Does anybody have the car stereo manual in English (punto 11.2000)? I have the manual, but it is in Deutsch and I can't figure out anything from it. The system is cassette/radio with 6 speakers+subwoofer.
Thanks in advance
Thanks in advance
Yes, I have one. Give me a few minutes and I'll scan a copy for you.
[EDIT]
OK. Try this. Click here. 250Kb PDF.
[/EDIT]
You should get a fourth option - Fade. At a guess, something is not connected.
That's correct. However the radio will shut down itself after 20 (or is it 30) minutes. This clock is built into the Blaupunkt, not the car's management system. I can't remember the detail as I've replaced the OEM Blaupunkt with a much better Sony DAB Radio/CD player.
