Number your albums on the pen drive and SD card as CD01, CD02, CD03 etc, etc. The head unit will only recognise 10 albums/folders but each can have 99 songs. Your music must be MP3 or WMA files.
Thank you for yr advice, however nothing helps. i think the problem is my nav does not recognize the yatour. usually i get ''no cd'' warning. there is a connection problem
IT SAYS ''Regarding Fiat, Renault models, two black wires with metal ends (male+female) come along with CDC connector. If noise problem exists when using Digital Music Changer, please hook up the two grounding wires with each other'' AND MY YATOUR HAS SAME AS THIS AND I ATTACHED EACHOTHER HOWEVER AGAIN SAME PROBLEM.
