Sub and Amp advice please.
oliverkirman
I have a 12" Fusion en-ab 1120 sub woofer. It's 360 Watts Max power. I'm unsure about the RMS value, I was told it was 301-400 watts, does that seem right?
I also am unsure at what amp and wiring kit I will require?
I've never done an installation or ever had a sub kit before so if someone could just help me out that would be great.
Cheers!
Assuming you've got what's in the pic here - http://www.fusionelectronics.com/car/products/active-enclosures-encounter/en-12-active-box-enclosure it's an active sub, and doesn't need a separate amp. Just needs the cable to go from headunit to the box (twin RCA) and power and earth. I'm not very good at judging gauge, but I can tell you that the RMS value will be lower than the MAX power value, probably closer to 200wRMS but will still be punchy.
That's the one I have, It has two ports in the back of the box right?Also, will this be able too run with standard Grande Punto speakers installed?Thanks for the help!
I don't understand.. you want to replace the sub with speakers?
