The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 09-06-2005   #1
petroladdict's Avatar
Trader Rating: (0)
amp cooling
Right, want to mount a fan to help in the cooling process of my amp but don't know where to put the two wires to power it
petroladdict is offline
Old 09-06-2005   #2
oh me gums!
custard's Avatar
Trader Rating: (1)
custard has donated! United Kingdom
Re: amp cooling
one(probably black)will go to the ground(earth)other(probably red)will go to live. where you put the live is up to you. you can put it on a constant live on a switch or on an ignition live.
a cleverer wat to do it is to put it on a constant live through a relay that is switched via the amps remote wire so its only on when the amp is on
custard is offline
Old 09-06-2005   #3
Trader Rating: (0)
Re: amp cooling
cheers, now as im not very good with the old wire situation, how do u wire it up with a relay??
Old 09-06-2005   #4
oh me gums!
custard's Avatar
Trader Rating: (1)
Re: amp cooling
basically you connect the relay to your power source and then use the amp signal wire to 'switch' the relay. i'll try and dig up a diagram as it seems really complicated when put into words,and its really not
custard is offline
Old 09-06-2005   #5
Trader Rating: (0)
Re: amp cooling
thanks for your help, a diagram would be really helpful. Take it, it needs to be a 12v relay
Old 09-06-2005   #6
oh me gums!
custard's Avatar
Trader Rating: (1)
Re: amp cooling
so the remote lead could be your amp signal or ignition live depending on your preference and set up.
the ground is straight to the body work and 12v can come of the battery.
the 'connect to electronic component' goes to your fan's '+' feed.
then you just add a ground connection to the fan(s)
hope that helps.
dont forget to put a fuse in the supply!!!
custard is offline
Guide: How to wire an Amp Luke I.C.E 3 11-07-2005 18:33
Amp and sub help sparky762 I.C.E 6 26-01-2005 12:36
Need A New Amp bravaboy I.C.E 5 30-01-2004 16:51
(G) Simple question - hope it's a simple answer! DotSPF Uno 6 11-11-2003 23:18
