The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 28-03-2005   #1
Luke's Avatar
Trader Rating: (1)
Luke has donated! United Kingdom
Exclamation Speaker Sizes (DATA NEEDED)
Hi all,
This should help alot of people so could you please post the standard speaker sizes and locations for each car model listed below...
Cinq (done)
Sei (done)
Uno mk1 (Uno mk2 if different)
Bravo
Brava
Punto mk1 (done)
Punto mk2 (done)
Coupe
Old Panda
New Panda
Marea
Stilo
Barchetta
Doblo
Idea
Rimto/Strada
Tempra
Tipo
Ulysse
If theres any more that i havent added and feel should - let me know.
When i've collected the data i will put it into a nice chart
Luke is offline
Old 28-03-2005   #2
AKA Dan
D4NS's Avatar
Trader Rating: (0)
D4NS has donated! United Kingdom
Re: Standard Speaker Sizes (DATA STILL NEEDED)
CINQ
With a cinq you get 2 10cm speakers behind grilles under the wing mirror adjusters at the ends of the dash. You dont get rear speakers and there is no wiring for them installed. You can fit speakers in custom rear door cards very easily. 6x9's are a good fit if your wondering.
In the boot you can easily fit 2 12" subs in the standard sub enclosures, but will struggle to find room for more than 1 amp as well. 1 12" sub is recommended.
D4NS is offline
Old 28-03-2005   #3
Luke's Avatar
Trader Rating: (1)
Originally Posted by D4NS
CINQ
Exactly the kind of data i want to hear, cheers Dan
Luke is offline
Old 28-03-2005   #4
taffy git
gaz.d's Avatar
Trader Rating: (2)
gaz.d has donated! Poland
sei 10cms speakers in front behind dash grills, will need allen key to get acess to them, may require trimming in order to fit onto speaker grills
unsure of speakers in back, have never looked
possible location for rear speakers are parcel shelf and custom mdf rear quarts, although in drivers side rear quart size maybe restricted due too petrol filler neck being in the way - although 6x9's can squeeze in there but you will have to mark them up carefully before cutting
Events Calendar
Sunday 10th August Mitcar
Sunday 7th September Trax
Sunday 14th September Gaydon
19th-22nd September Butlins Skegness Weekender
gaz.d is offline
Old 28-03-2005   #5
Trader Rating: (0)
Malta
Punto mk2 2dr - Spk Locations - in front doors at the bottom
- at the back at the sides (near seat belt reels)
Size - Front - 17cm
- Back - 13cm
6x9 fit in the real parcel shelf
For a more extreme installation just pm me (Like 2 800watt amps and a 12" DVC sub while still keeping the spare wheel accessable)
--- Punto mk2 8v---
*Int & Ext neons**Tinting**Int Alum trim**Momo gear set**Momo pedal set*
*Body graphics**Custom Ice install**Custom A'Pex Integration CAI**Sports exhaust**Racing Seat Belts**Removed seats**Lexan Windows**Weight reduction*
Neo-The Matrix is offline
Old 28-03-2005   #6
Was VXR enough :(
wolfracepunto's Avatar
Trader Rating: (0)
wolfracepunto has donated! United Kingdom
Punto mk2 (3dr dont know if same as 5dr)
Front, behind grill in doors: 16.5cm
Rear, either side of parcel shelf: 10cm
Tweeters in front door- tweeter's a tweeter isnt it??
Fiat Punto Active '02' > Skoda Fabia vRS '05' > Vauxhall Astra VXR '06' > SEAT Ibiza 20VT FR '56' & Honda CB600FA Hornet '58'
wolfracepunto is offline
Old 28-03-2005   #7
Trader Rating: (0)
Malta
Erm, my tweeter was on the speaker itself (ie 2 way coaxial)
About the sizes I have the boxes of the after market speakers near me (got them to make sure) and one says "17cm", the other says "13cm". Both are Pioneer speakers. To tell you the truth I had 10cm speakers but they were slightly smaller and had to use an adapter plate.
--- Punto mk2 8v---
Old 28-03-2005   #8
Was VXR enough :(
Trader Rating: (0)
You sure those coaxial speakers were the standard factory fodder?
Reading from the manual, the standard fit speakers in the front are 16.5mm (im sure 17cm would fit) and rear are 10cm. Tweeter is under trim near door mirror adjuster.
Old 28-03-2005   #9
Fat pigeon... APPLE!
JonnyBoy's Avatar
Trader Rating: (1)
JonnyBoy has donated! United Kingdom
Punto Mk1: Speakers mounted in dash are 8.7cm, ones in rear shelf supports are 10cm.
Then: mildly-modded Punto 55SX; rusty Ford Capri 2.0 Laser
Now: mk2 Focus Zetec Ti-VCT; same Capri, less rust
Soon: Bravo Dynamic 150 MJet, in red, with extra toys
JonnyBoy is offline
Old 28-03-2005   #10
Trader Rating: (0)
Malta
Wow, I am off to find those tweeters!!!
About the rear speakers I am not gonna go against you cause when I ordered my car there was an option for "Uprated sound system" and I chose it just to get the face plate and the wiring. So it might have got a mod done to install larger speakers.
--- Punto mk2 8v---
Old 31-03-2005   #11
Luke's Avatar
Trader Rating: (1)
Still plenty more data needed... Will update the 1st list of the ones done now. Then will possibly post a link in each section.
Luke is offline
Old 02-07-2005   #12
GhettoMoose's Avatar
Trader Rating: (0)
Re: Speaker Sizes (DATA NEEDED)
Anyone got details on Punto GT front speaker sizes ?
Ghetto Moose - Running : 145BHP ,Punto GT2, BP270 Piper Fast Road Cam, Lemans DVK005 Dump Valve, Drilled Airbox with K&N panel filter. Next - De-Cat
GhettoMoose is offline
Old 23-07-2005   #13
Trader Rating: (0)
sweet! but is it worth changing those dash speakers since they are so small??
badboy is offline
Old 23-07-2005   #14
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
Marea saloon rear speakers - 5"x7" mounting depth 60mm. You can fit deeper ones under the standard grilles, but you'll need to pack them up. Metal parcel shelf gets in the way.
Front speakers - 5"x7", not sure on max mounting depth. You can get adaptors for the bravo/a/marea to fit 13cm components in the front doors though.
Dash tweeters - not sure on size.
Pete, Clubcento technical bod.
Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento
fixitagaintomorrow is offline
Old 23-07-2005   #15
Trader Rating: (0)
I didn't know there were so many fiats!
datprogrammer is offline
vB code is On
Mk2 2002 speaker sizes mastermick70 Punto > Styling 9 17-01-2005 21:17
Bravo Speaker Sizes TidyBoy I.C.E 3 10-04-2004 08:27
speaker sizes jonesy051 I.C.E 1 12-03-2004 15:17
Advice needed on speaker upgrade! nawtwrong Punto 3 17-01-2004 22:18
Fiat stilo front speaker sizes monster109 I.C.E 0 04-08-2003 00:59
