The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 04-02-2008   #61
Trader Rating: (0)
Re: Speaker Sizes (DATA NEEDED)
hi,
can you specify an hi-end combination system with 4inch speakers alone for mk2 uno?i dont want to make extra provisions.but wud love to get max out of an 10cm itself..and an head unit which wud suit it?
ashokdurai is offline
Old 26-03-2008   #62
Trader Rating: (0)
MK1 front speakers are 8.7cm you say? Smallest size I can find on the internet are 10cm, and i gota replace my front speakers as they are both blown. Do you think 10cm speakers would fit in thier place?
stayinfly is offline
Old 4 Weeks Ago   #63
Rip'n'Burn
Smiler121's Avatar
Trader Rating: (1)
Smiler121 has donated! United Kingdom
Smile Re: Speaker Sizes (DATA NEEDED)
Originally Posted by Diwiak View Post
And what depth front dash speakers will fit into cinq ???? Thinking about Sony XS-F1035 (10cm, 42mm depth, 3way)
You mainly have to be careful about the diameter of the magnet if going for deeper speakers, not just the actual depth. If the rear part of the speaker is larger diameter (existing ones are weedy) it fouls the heater pipe behind the speaker - I diddn't have to worry 'cos I have the hand vents blocked so just cut a chunk out of the pipe
This evening I fitted a pair of Hertz 100.3 10 cm speakers in there which even have a raised tweeter that wants to foul on the grille - you can get around that by putting a washer between the speaker & the grill where it screws on
This shop has a decent range for comparison purposes.
http://caraudiosecurity.com/shop/pro...s_id/8401.html
Originally Posted by xracer View Post
53 plate seicento sporting: 10cm in front undo with allen key. strange shaped hard to replace.
Rear shelf ones are 16cm and have basket that they sit in. so replace with components
Boot enough space for a couple of 12" subs and amp.
The curved grill is pretty easy to swap onto if the speakers are small enough, BUT it does mean that if the speakers are too deep you can't just easily cheat & have them slightly raised out of the dash like you can with some circular grilles - you have to put them behind it.
That which does not kill us makes us stronger!!!
Smiler121 is offline
Old 4 Weeks Ago   #64
Rip'n'Burn
Smiler121's Avatar
Trader Rating: (1)
Cool Re: Speaker Sizes (DATA NEEDED)
P.S: Sorry, I have a Seicento not a Cinquecento.
Old 2 Weeks Ago   #65
Trader Rating: (0)
Hi, you can get some from Here, got a set of the Alpine SXE-0825S myself the other day, really good replacement fair play. only place i could find that actually had them in stock too, and if u order before 2pm they'll be on ur door first thing the following morning.
ps- i dont think 10cm would fit.
pontyjon is offline
vB code is On
Mk2 2002 speaker sizes mastermick70 Punto > Styling 9 17-01-2005 21:17
Bravo Speaker Sizes TidyBoy I.C.E 3 10-04-2004 09:27
speaker sizes jonesy051 I.C.E 1 12-03-2004 15:17
Advice needed on speaker upgrade! nawtwrong Punto 3 17-01-2004 22:18
Fiat stilo front speaker sizes monster109 I.C.E 0 04-08-2003 01:59
