| | #31 | ||
| Re: Speaker Sizes (DATA NEEDED) In addition to my last message I've just fitted the adapters to the rear... As I have a 5dr punto I had to hack a corner off of the adapters so I wouldn't obstruct the seatbelt winder. Getting 5"ers make a big difference and together with a nice head unit it's very very smooth indeed - very happy with my purchase - just in case you want to copy... http://caraudiosecurity.com/shop/pro...cts_id/56.html & http://caraudiosecurity.com/shop/pro...cts_id/49.html Happy fitting!
| | #32 | ||
| Re: Speaker Sizes (DATA NEEDED) Fiat Tipo : Fronts : 6" x 4" speakers under grilles in dashboard top, BUT!!! Have to cut away some of the plastic under the grilles to fit upgraded speakers due to their bigger magnets etc. Fairly straightforward. Rears : 4" round speakers under plastic shelf next to the parcel shelf, BUT!!! Hard to get access to screws on passenger side because of boot light, you basically have to lie in the boot to screw up the new speakers, and because the original speakers have a 6mm thick base you will probably need shorter self tappers (1/2" no. 8) to fit the new speakers. Should be able to try them out later today...
| | #33 | ||
| Re: Speaker Sizes (DATA NEEDED) For the Fiat Bravo: Front: 5x7 inch speakers in the door panels, can fit 16cm speakers without using brackets though. Also has location for tweeters on the dash - mine had wiring for them but no tweeters... Rear: 13cm speakers, can't fit bigger without modding The magnets on these speakers are exactly the same size, which isn't a good sign!
| | #34 | ||
| Re: Speaker Sizes (DATA NEEDED) New Panda: standard setup: Two coax(I hope!) 165 mm fulla ranges in the front doors and two coax 130 mm in the rear doors. "Hi-Fi" setup: Front: Two 165 mm woofers in the doors in and two cheap(about £ 1.5 each!) 30 mm tweeters screwed into the plastic plates beside the handles(normally these are fake!). Rear: Two "better quality" coax 130 mm full ranges in the rear doors and the same plastic "fake tweeter" plates beside the handles. Sub: flat type under the passenger seat. Today I went to a professional car audio shop: the man showed me a catalog with an adaptor to mount the 165 mm speakers in the rear doors. I think it's a typo, because the rear grille is so smaller than front one!
__________________ - --> Matteo Barducci <matbard@tin.it> | |||
| | #35 | ||
| Join Date: Apr 2004 Location: middlesbrough, United Kingdom.
Thanks: 0 Trader Rating: (0) | Hi, what size speakers are in the doors of a mk1 punto sporting?,and what are the best speakers to replace them with?,also i want a straight swap or a little modding needed as pos,as its bleeding freezing out there and i aint got no garage!,lol!,cheers guys!!!
__________________ life is the fabric of thought,woven into the loom of the mind | ||
| | #36 | ||
| Doblo Moderator | I am led to believe that the speaker sizes for the Doblo are 10cm, and there are six, two in the door, two in the lower dash, and two in the rear by the rear windows either side. I will post more info when I actually get mine
__________________ No Longer a Doblo Owner | ||
| | #37 | ||
| Doblo Moderator | Cannot seem to edit post above but here goes! These are the sizes for the DOBLO passenger versions. Front Dash Mounted Speakers: 100mm Front Door Mounted Speakers: 165mm Rear Window Shelf Speakers: 95x154mm Standard Cargo versions just have the Dash Mounted speakers.
| | #39 | ||
| Re: Speaker Sizes (DATA NEEDED) 53 plate seicento sporting: 10cm in fron undo with allen key. strange shaped hard to replace. Rear shelf ones are 16cm and have basket that they sit in. so replace with components Boot enough space for a couple of 12" subs and amp.
| | #40 | |||||
| | #41 | ||
| Re: Speaker Sizes (DATA NEEDED) Does anybody know the size of the standard fit speakers in the 3 Door Punto Grande? ![]()
| | #42 | ||
| Re: Speaker Sizes (DATA NEEDED) Punto MK1 Door Cards 16.5cm/ 6.5'' speakers will fit in those.Depth is normally two inches, without cutting or using spacers. In dash, 8cm speakers, good for a 1'' tweeter. If you fancy 6x9s, rear quaters, loads-a-room, same with parcel shelf. (not a fan of 6x9ers) Boot can hold a few subs.
| | #43 | ||
| Re: Speaker Sizes (DATA NEEDED) And what depth front dash speakers will fit into cinq ???? Thinking about Sony XS-F1035 (10cm, 42mm depth, 3way)
__________________ Revival in progress - Grey Cinq 1.1 Sporting'96, Silver 13" alloys, Black 165/55 tyres, Red seatbelts, Lotz Of Stickerz , Sony >Xplod< 880W I.C.E, ColdAirIntake with Sprintfilter, De-cat with backbox edit. Named Theresa![]() | |||
| | #44 | ||
| Re: Speaker Sizes (DATA NEEDED) i orderd today sony cdx gt 414U and alpine 5x7 sps 570A for front doors. i hope speakers will fit the doors.
| | #45 | |||||
| 999cc CLX Owner | Re: Speaker Sizes (DATA NEEDED)
13cm speakers in custom DIY pods (Tight fit) 10cm speakers in rear panels (Remove panel and cut around outline on wood) parcel shelf speakers aren't recommended as the shelves are weak. You could build an MDF shelf but then you'll probably need an upgraded strut
| Mk2 2002 speaker sizes | mastermick70 | Punto > Styling | 9 | 17-01-2005 21:17 |
| Bravo Speaker Sizes | TidyBoy | I.C.E | 3 | 10-04-2004 08:27 |
| speaker sizes | jonesy051 | I.C.E | 1 | 12-03-2004 15:17 |
| Advice needed on speaker upgrade! | nawtwrong | Punto | 3 | 17-01-2004 22:18 |
| Fiat stilo front speaker sizes | monster109 | I.C.E | 0 | 04-08-2003 00:59 |
