The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 21-03-2005   #1
taffy git
gaz.d's Avatar
Trader Rating: (2)
gaz.d has donated! United Kingdom
power invertor
i need a power invertor for the car, im finding lots of invertors, but am not sure of the rating that i need - its a normal 240v applicance that i want to run
any links or info appreiciated
Gaz
Marea Weekend
gaz.d is offline
Old 21-03-2005   #2
The Negotiator's Avatar
Trader Rating: (0)
The Negotiator has donated! United Kingdom
Re: power invertor
What wattage is the device Gaz? See the label on it, if it gives you only a amperage that will do. If none, tell us what the device is.
Now drives: '52 Megane 1.9dCi
Past:
Y-reg Fiat Brava JTD (Pale Blue) (2006)
M-reg UNO (2003-2004)
'51 Fiat Brava 80 SX (black) (2006)
The Negotiator is offline
Old 21-03-2005   #3
Nothing's Impossible!
brickfoot's Avatar
Trader Rating: (0)
brickfoot has donated! United Kingdom
Re: power invertor
i think they start from 150w rated, It really depends on what you want to run on it,
150w would be suitable to run a laptop from i beleive but anything like a powerdrill/washing machine/lawnmower would need a higher ratingthan 150w
brickfoot is offline
Old 21-03-2005   #4
Trader Rating: (0)
Re: power invertor
Even a kettle or (not sure this matters to Gaz ) a hairdrier uses above 300W. Typically a kettle is about 2kw (i think) and a hairdrier is 1.2Kw. It's also important to know what actual item you're using as some simply won't work with the majority of invertors (to do with the sine wave they produce).
Past:
Old 21-03-2005   #5
arc
this is where i stand
arc's Avatar
Trader Rating: (0)
arc has donated! United Kingdom
Re: power invertor
yup, some things dont like 'modified' sine waves. Your about right re kettles - but they have heating elements in so what do you expect!
My invertor does 800w continous and 1200w peak, and it says with regards to power consumption - for every 10w output you want, it'll need 1A input. So mine is getting some phat cabling put in.
Not that i use it for anything.. but its there should i need it
arc is online now
Old 21-03-2005   #6
Trader Rating: (1)
Luke has donated!
Re: power invertor
Pretty much all is covered
I'll just add, if you do find the one you need (rating wise) check out Maplins to buy them - they've proven to be cheap a while ago when i got one.
Luke is offline
Old 21-03-2005   #7
taffy git
gaz.d's Avatar
Trader Rating: (2)
Re: power invertor
i was gonna get one from ebay, then checked on the maplin site and came across a few different rating ones, i want it to power a laptop, kettle and fridge if needed
Gaz
Marea Weekend
gaz.d is offline
Old 21-03-2005   #8
arc
arc's Avatar
Trader Rating: (0)
Re: power invertor
imo you'd be better off buying a fridge designed for 12v, a kettle designed for 12v, and a laptop charger designed for 12v
arc is online now
Old 21-03-2005   #9
taffy git
gaz.d's Avatar
Trader Rating: (2)
Re: power invertor
ooo can you get 12v for the laptop, it will save me loads of hassle
as for the fridge, i been told to get one for the summer and they dont want one of them little farty ones
Gaz
Marea Weekend
gaz.d is offline
Old 21-03-2005   #10
taffy git
gaz.d's Avatar
Trader Rating: (2)
Re: power invertor
i have just brought a 300w one, how do i connect it to the car - it comes with fag lighter lead and a lead with crocidille clips on, i would like to run it off the 4 way power splitter i got running my amps, it this possible??
Gaz
Marea Weekend
gaz.d is offline
Old 21-03-2005   #11
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
Re: power invertor
i got a booster box thing. has jumpleads on it a tyre pump a light and a 300w inverter.
i would think you could wire yours from amp wire thing, but an extra fuse always helps stop bad things happerning
Binki
dave is online now
Old 21-03-2005   #12
taffy git
gaz.d's Avatar
Trader Rating: (2)
Re: power invertor
i think the invertor might have a fuse or something like that on it, well it says it got a overload protection, so i assume it stops working if something bad happens to it
cheers everyone for the help - just thought do these things run playstations too
Gaz
Marea Weekend
gaz.d is offline
I.C.E How to - Power Issues Luke I.C.E 9 21-07-2005 13:40
Guide: How to wire an Amp Luke I.C.E 3 11-07-2005 18:33
(G) Fiat Uno power loss + starting problem?? Karlakarl Uno 5 05-01-2005 09:00
(T) Powerflow - More Power? mckcrich Cinquecento / Seicento 9 04-12-2004 17:55
(T) Seicento Power Steering? dawozere Cinquecento / Seicento 7 27-02-2004 16:30
