The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 15-03-2005   #1
Banned
Trader Rating: (0)
Ben R has donated! Christmas Island
Sub connection to connect nav +
Hi anyone know if you can link an after market sub & amp to the connect nav+ system on a Stilo abarth?
Ben R is offline
Old 17-03-2005   #2
Luke's Avatar
Trader Rating: (1)
Luke has donated! United Kingdom
Re: Sub connection to connect nav +
Hi
This is quite a common question that unfortunately has gone unanswered. I cant say for definate this will work, but in logic, it should.
Connect your aftermarket amp up using the rear speaker outputs from the stereo (like in the punto's active sub) if there are no RCA outputs. Now from here you have 2 options... You can get an amp that has high speaker level inputs (therefor all you do is have to run the wire in) or get an RCA convertor whereby it turns the speaker level input to a levelled RCA output. From then you can connect up the amp as normal.
If anyone can think of another way...
Luke is offline
vB code is On
how do i connect a sub to connect nav + scrod Stilo > Technical 3 24-02-2005 15:16
New Ulysse Connect Nav + Stu DemonD Ulysse 126 18-06-2004 00:16
Connect Nav -vs- Connect Nav+ Mikas Stilo > Technical 7 30-04-2004 01:38
SOS button + no manual for connect nav coolchef Stilo > Technical 5 04-09-2003 03:46
Connect Nav - How do I Play[?] Gladiator111 Multipla 1 05-07-2003 23:22
