| Supressors for Punto Hi guys I've got the dredded whizzin noise comeing from my speakers Ive worked it down to its the RCA cables on my second ( smaller amp ) Ive bought a supressor which is a black box with a solderd RING terminal and one Yelllow wire.... Anyone have a clue how to wire these up to the alternator? ive looked in engine and seems as if i have to get right under it to access the wires..... anyone, cheers
__________________ Ghetto Moose - Running : 145BHP ,Punto GT2, BP270 Piper Fast Road Cam, Lemans DVK005 Dump Valve, Drilled Airbox with K&N panel filter. Next - De-Cat | |||
| Re: Supressors for Punto Didn't the suprressor come with instructions? And you've said you worked it down to the RCA feed of your amp... Is the RCA fed near the power lines? If so you may need to re-route it. If it was your alternator then wouldnt your other amp have problems too? Alternatively, i could suggest you fit a 1 farad powercap to smooth off all the crap on the power feed (would effectively so the same as a supressor but more useful when cranking up the volume too).
| | #3 | ||
| Re: Supressors for Punto Hi, The Rca Cables are not bunched with power but do come within 5cm of each other at some points in the installation. The Noise only really comes out of the 6x9's, doesn't effect the front speakers, or doesn;t effect the subs..... I have tried swapping the 6x9's from one amp to the other, and only happens on the one amp. ( the smaller bridged one intended for the 6x9's ) Ive already bought the supresser, and ive seen power caps for around the £35 mark. But Depending on how hard the Supressors are to fit, ( mine seems in an awkward place next to oil sump) Am I best trying another small amp on the 6x9's before I go putting this supressor or a power cap in ?
| | #4 | |||||
| | #5 | ||
| Re: Supressors for Punto I did check this the gain is just under half way, and makes no difference to the sound. I will try another amp first I think. Lend a friends or somthing
| | #6 | ||
| Re: Supressors for Punto By the way, here is picture of before and after setup.... ![]() ![]()
