| Shielding 6x9's from the sub..advice please Hi all Getting a lot of vibration through from my amped sub.My 6 x 9's are not amped(at the mo) and as a result I get a lot of vibration on higher volume. Any ideas here..apart from remove the 6x9's! Cheers Peter
__________________ Fiat Brava owner-no mods...yet! | |||
| Ah. Not good... | Re: Shielding 6x9's from the sub..advice please Are they mounted to your parcel shelf? | ||
| | #3 | ||
| Re: Shielding 6x9's from the sub..advice please Sorry,yes they are. Pete
| | #5 | ||
| taffy git | Re: Shielding 6x9's from the sub..advice please i have seen someone put nipples over there 6x9 magnets was just heated plastic moulded over a bowl
__________________ Gaz Marea Weekend | ||
| | #6 | ||
| Re: Shielding 6x9's from the sub..advice please Hi all Cheers for that I'm now looking at taking out the 6x9's and amping the front components as I think this be an ongoing problem cos thinking about it the 6x9's are sharing airspace with the sub. I'll also try to turn the gain to the sub down a bit to see if that helps. what do think of that idea? Peter
| | #7 | ||
| taffy git | Re: Shielding 6x9's from the sub..advice please which way is the sub facing? up towards the 6x9's or away from 6x9's i faced mine away and it sort of helped, but i got rid of the 6x9's soon after and let the sub do all the bass for me
| | #8 | ||
| Re: Shielding 6x9's from the sub..advice please Gaz the sub is facing away. Sounds like ditching the 6x9's might be a good idea.I prefer the bassy sound anyway. Out of interest is it worth considering making a heavier shelf-will that have a difference?(without 6x9's) Cheers Peter
| | #9 | ||
| taffy git | Re: Shielding 6x9's from the sub..advice please i would imagine a heavier shelf would seal the sound in the boot, well in theory it should work as the parcel shelf would not bounce up and down amp up a good set of comps and set them to HP and you will notice the difference straight away i ditched the 6x9's in my sei for 4 6.5" comps and they give me the high notes (there is a name for these ), the sub gives me the bass
| | #10 | ||
| Re: Shielding 6x9's from the sub..advice please 6x9s in different air space ie rear qtrs or remove them. fit more powerfull speakers upfront and it will sounds better anyway.
__________________ Ex punto mk2 owner 1.2 8v with 94bhp. Now owns a seicento sporting abarth bog standard and loving it! | |||
| | #11 | ||
| Re: Shielding 6x9's from the sub..advice please Cheers So my next question will be to ask for your recommendations on fronts. Its for a Brava so 13cm's will be needed.Not too sure about my budget though yet.It seems that JBL's go for around £40 new on Ebay. Also I could get hold of a 200w 2ch amp to power these from a mate cheap. Is this likely to do the jobbie..? Thanks again for your expertise guys. Peter
| | #12 | ||
| taffy git | Re: Shielding 6x9's from the sub..advice please i think some kind of adaptor is needed to fit 13cm speakers to the front of a brava, im sure i read it somewhere, hopefully one of the bravo/a peeps will be able to help on that as for 13cm speakers, i assume you want comps so will need somewhere to fit the tweeters and cross over, easily done - my personal choice for comps are either jbl or infinity, i base my choice on personal experience cause for what you pay you get lots ![]() expertise - i dont have any, i have managed to blag my way through a couple of installs, you just need to get in there and have a play
| | #13 | ||
| Re: Shielding 6x9's from the sub..advice please Yes,I think you're right about the adaptors looking at previous poats. What about thoughts on amping them.? Peter
| | #14 | |||||
| | #15 | ||
| taffy git | Re: Shielding 6x9's from the sub..advice please amp should be good enough, it wont be powering much, just make sure it works before you part with the cash
| ICE advice..not sure whats best..!! | peterp | I.C.E | 1 | 02-02-2005 12:54 |
| Should I remove my 6x9's...?? | peterp | I.C.E | 4 | 02-02-2005 12:51 |
| coupe ice advice please.......... | sammiboo | I.C.E | 4 | 28-09-2004 09:39 |
| | Straight Outta Compton | Cinquecento / Seicento | 2 | 22-08-2004 23:44 |
| How to Install 6x9's??? | Straight Outta Compton | I.C.E | 0 | 22-08-2004 09:55 |
