The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 17-02-2005   #1
Trader Rating: (0)
Question Subwoofer enclosures
Hi, am after a bit of guidance regarding sub enclosures.
My home audio speakers are packed with some foam or acoustic material of some kind, should my new sub enclosure also be filled with something similar before I fit the cones? I bought the cones and enclosure separately so it is just a bare box at the moment.
Cheers!
samwhite59 is offline
Old 17-02-2005   #2
Trader Rating: (1)
Luke has donated!
Re: Subwoofer enclosures
Cheers!
Its only worth packing out your sub boxes if the sub box is sealed not ported, and it doesnt make too much of a difference. Basically it makes it think the box is a bit bigger than it is therefor deep bass reprocussions are clearer.
Luke is offline
Old 17-02-2005   #3
Trader Rating: (0)
The box is sealed, so sounds like it is worth doing then! Having done some research online is seems like Polyfill or fiberglass insulation is the way to go.
Damping/Filling
It is advisable to put damping material inside a subwoofer box. Pillow polyfill and fiberglass insulation are common, though polyfill is a lot easier on your skin. This increases subwoofer efficiency by dissipating some energy that affects the sub, particularly the voice coil. Polyfill also "fools" a sub into thinking it is in a bigger box. Play around with different amounts of polyfill until you get the desired results.
Anyone know a good cheap source for either of these?
TIA
Old 17-02-2005   #4
Trader Rating: (1)
Luke has donated!
TIA
Have you got a local car audio shop (not halfrauds)? They should stock it, and wont cost much.
Or
http://www.incarexpress.co.uk/view_p...hp?partno=K820
Luke is offline
Old 17-02-2005   #5
AKA Dan
D4NS's Avatar
Trader Rating: (0)
D4NS has donated! United Kingdom
Cotton wool works exactly the same at a lot lower price. Yes it is worth doing, it makes the sub last longer with a slightly deeper bass as luke said. When you get it in slowly increase the sub volume over about a week, starting quite low and woring it it. You will find it will work a lot better than 1 that is turned straight up, the sub will also last longer. Its kind of breaking it in.
D4NS is offline
Old 17-02-2005   #6
Trader Rating: (1)
Luke has donated!
A very important fact thats often overlooked!
Luke is offline
Old 18-02-2005   #7
Trader Rating: (0)
Thanks for the replies guys. I'll check out cotton wool (when I can find a big enough bag full for two subs) and also maybe see how much fiberglass roof insulation rolls are in B&Q over the weekend.
Old 18-02-2005   #8
Trader Rating: (0)
lots of sq guru's here I see pmsl.
making a box bigger is pointless unless your box is too small.
Check with the documents with the sub what enclosure it needs sealed and compare that with what you have bought, if its the same, wicked. if not then stick blocks of wood/wadding until it is. (blocks of wood to make it smaller, wadding to make it bigger).
Try not to do anything permanent like polyfill as this is harder to remove if you have got it wrong or choose to change your sub...
I personally would screw it in, if it sounds wrong experiment, if not put your feet up and watch eastenders.
Ex punto mk2 owner 1.2 8v with 94bhp.
Now owns a seicento sporting abarth bog standard and loving it!
Lowtechguy is offline
Old 19-02-2005   #9
Ah. Not good...
chaos's Avatar
Trader Rating: (3)
chaos has donated! United Kingdom
My JBL sub's instructions said to loosely stuff the enclosure with fibrefill. So I used an old pillow - the stuff's quite stiff - I found I didn't need to attach it or anything.
Try a local fabric shop - they are bound to sell fibrefill - but it could be expensive!
HTH
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
(T) Punto Subwoofer rmcsherry Punto 10 09-02-2005 21:50
(G) Question on Hi-Fi and subwoofer. apierdomi Stilo 0 10-09-2004 16:29
(T) Stilo subwoofer STILO8569 Stilo 1 06-09-2004 13:12
Solved! - Punto SubWoofer not working . . . icedpunto I.C.E 3 20-01-2004 05:14
subwoofer wiring graham_florey I.C.E 6 20-12-2003 01:26
