i can never understand these people that want to wiegh the car down with so many speaks oh wait in know its cause they cant afford lowering springs so they want to fill it with speakers to get the low look
no being serious now why not just save up and get some really good quality speakers and a decent head unit to power them you can have all the speakers you can fit in a car with as many amps as you want and it will never sound as good as a good head unit with a set of speakers that are power output matched to it
right well before u all start taking the ****. Fiat seicento's aint the best cars are they, 900cc of ****ness. What the point in trying to make them faster, waste of time and money may aswell spend it on audio. If i wanted speed id use a moped, as it would probably beat it.
I have already made some custom door pods in the front and rear with in phase speakers and amped them both on a 4 channel amp matched to the rms of the speaker, as for the headunit it is a sony xplod headunit 52 watt amp per channel. I also have a audiobahn sub running at 900watts rms on a in phase amp.
The car is already lowered 60mm so no need for the sarcy comments. Many thanks
As everybody has said why dont you save your money and get something really good rather than craming loads of cheap speakers in the car.
You do understand that more speakers doesnt actually mean more volume! Also having speakers making sound all around you playing the same frequencies makes for terrible listening. It gets all messy and you end up with just noise. Think of the poor music
Have you sound deadened as that will help a lot.
You can put massive power through dedicated Mid Bass woofers. For example i am using 360w RMS on each of mine in the front doors :devil:
Tweeters then need to be placed properly. Just under Mid way up the A pillar is good. That way the high frequencies will be closer to your ears.
probably run the front speakers at 200 watts each then in tht case, as for the rear ones i currently have 13cm speakers in there can u fit 17cm speakers in there ?
