Stilo:- Are the Hu Pins different for Visteon
Kent
I have a couple of the removal keys (albeit different thickness') and the HU clips just wont release. Is there a trick that im missing.
I have removed loads of Fiat Radios for other people, its always going to be your own thats problematic :bang:
Ive used a small flat bladed screwdriver with a 3.5mm shaft that worked fine, but also hanging wires as used for hanging point of sale in shops, shortened and modified, both worked for me.
You have to give it a hard push, and it may well feel like you will do damage but they do come out.
Dan
I even resorted to hammering nails in there and they still didnt release. just dug the nails into the plastic.
I hammered the keys in and that didnt do it :bang:
Ill try some flat heads tonight cheers.
Open the upper glove box, and remove the small cubby hole to the RHS of the radio, this should give you access to the release clips on the sides of the radio (from memory)
Nice one, if all else fails ill give that a go. I just dont want to fiddle around that upper box too much. This car actually had the door on it lol.
