| Pioneer Headunit? I recently got the pioneer p80mp headunit for my punto mk 2 2002 model ha any one else got this unit and if so how the hell do you wire it in becasue of the two looms from the car and only one in the back of the headunit do you have to get an adaptor or re-wire the loom PLEASE HELP!!!
| AKA Dan | Re: Pioneer Headunit? Go into Halfrauds (halfords) and ask for a wiring harness adapter or ISO adapter for a mk2 punto. It'll cost u bout £8 iirc. Or you can hardwire it, depends what u wanna do. Hope this helps.
__________________ http://www.fiatforum.com/gallery/dat...ed-4_copy1.jpg | ||
| | #3 | ||
| Join Date: Oct 2003 Location: buxton the land that time forgot
Thanks: 1 Trader Rating: (0) | Re: Pioneer Headunit? hi there what do you mean 2 looms ?? i though all stereos had space on back for the black block of wires and the white block of wires? or are pioneer different ?? there is also a multi coloured block of wires but you dont need them just leave them hanging they are only for the on board to computer to check you have put in the security code. so not needed without the original stereo
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm | ||
| | #4 | ||
| Re: Pioneer Headunit? As per the first reply i would assume that you have removed the FIAT head unit which has the FIAT proprietary wiring on it and you need the ISO (international standard) interface which allows it to plug and play. As is said you will need to get a custom part. www.caraudiodirect.co.uk will supply you the part if halfords cannot.
| upgraded headunit | jay316 | I.C.E | 3 | 07-01-2006 20:16 |
| Headunit? punto mk2 2002 | mastermick70 | I.C.E | 5 | 20-01-2005 23:24 |
| Which headunit? | GhostWKD | I.C.E | 13 | 01-06-2004 20:58 |
| | lambert82 | Bravo / Brava | 2 | 24-05-2004 22:18 |
| returned my headunit :( | syphon123 | I.C.E | 6 | 14-03-2003 06:03 |
