| More ICE Please | Help Line Driver Hi i am trying to find a Line driver to split 1 RCA Signal and amplify it to atleast 3 and i can only seem to find the VIBE one does anybody have any suggestions.
__________________ Cerwin Vega Stroker Pro 12 on USB 3000 Tuned to 50Hz ATM, Morel Elate Mids, Altec X-overs and Tweets on DLS A7, O gauge wiring. Blaupunkt Casablanca HU (Does it Stay). 120GB HD 2Ghz Carputer with 8" Touch Screen. Tinted windows, Custom built exhaust, GSR Induction Kit, Snap off steering wheel, Remapped to 126 BHP 116Ft/Lb. Next to come, Finish fitting sub and full sound deadening and fast road disks and pads. | ||
| Re: Help Line Driver Look out for a Phoenix Gold TLD66.
__________________ Black 100HP Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller. Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier. Chord Epic speaker cable and Anthem RCA leads. | |||
| | #3 | ||
| More ICE Please | Re: Help Line Driver That requires one input to each output doesnt it.
| | #4 | ||
| Re: Help Line Driver You know I'm not too sure, just had a look at the manual and it doesn't state either way.
| The following user says "Thank You!" to paulbfd for this useful post: | ||
volxstu (24-07-2008) | ||
| | #5 | ||
| More ICE Please | Re: Help Line Driver I had a look on the net and by the looks of it it does as there is an input next to each output terminal.
| | #6 | ||
| Re: Help Line Driver Do your amps not have a line out? Could just use some short RCAs then.
| | #7 | ||
| | #8 | ||
| More ICE Please | Re: Help Line Driver I am taking the crap 3.5mm output from the computer converting that to RCA and then i am left with one set, so i need the driver to split it and amplify it as i dont think a computers sound card will give a very good quality signal. Found this http://cgi.ebay.co.uk/Pyle-7-Band-6-...3286.m14.l1318
__________________ Cerwin Vega Stroker Pro 12 on USB 3000 Tuned to 50Hz ATM, Morel Elate Mids, Altec X-overs and Tweets on DLS A7, O gauge wiring. Blaupunkt Casablanca HU (Does it Stay). 120GB HD 2Ghz Carputer with 8" Touch Screen. Tinted windows, Custom built exhaust, GSR Induction Kit, Snap off steering wheel, Remapped to 126 BHP 116Ft/Lb. Next to come, Finish fitting sub and full sound deadening and fast road disks and pads. Last edited by volxstu; 24-07-2008 at 14:01. | ||
| | #9 | ||
| Re: Help Line Driver http://www.caraudiodirect.co.uk/sign...s-c-29_32.html Any of those take your fancy? Delta Box is in that list too at a reasonable price.
__________________ Fiat Punto Mk2 2003 1.2 Owner ![]() Ice- Vibe SE-K 575 Watt 6x9's, Fli 800s Amplifier, Alpine SPR-17C coax's, Vibe SQ12 Active Sub w/Integrated 600WRMS amp. | |||
| The following user says "Thank You!" to chris18790 for this useful post: | ||
| | #10 | ||
| More ICE Please | Re: Help Line Driver Looks like im going to have to go for the delta box all the others are a bit out of my price range as i only really wanted to spend under £100 as im not sure if this is even the right rout to go so could be money wasted.
| | #11 | ||
| *custom name* | Re: Help Line Driver how bout a phoenix gold tld22 run into an active crossover or something like that. just let the line driver do the work of amplifying the signal then use a crossover/processor to split and tweak it theres a guy in my work says he has a 3 channel line driver. dont know if he uses it but ill ask him how much he wants for it and what model is it
__________________ 1.2 3dr stilo dropped on claws & a suzuki bandit v | ||
| | #12 | |||
Actually for now i may just cut the other box off and fit it all around that so i waste even less money so i can buy the second battery and relay.
__________________ Cerwin Vega Stroker Pro 12 on USB 3000 Tuned to 50Hz ATM, Morel Elate Mids, Altec X-overs and Tweets on DLS A7, O gauge wiring. Blaupunkt Casablanca HU (Does it Stay). 120GB HD 2Ghz Carputer with 8" Touch Screen. Tinted windows, Custom built exhaust, GSR Induction Kit, Snap off steering wheel, Remapped to 126 BHP 116Ft/Lb. Next to come, Finish fitting sub and full sound deadening and fast road disks and pads. | |||
| | #14 | ||
| | bodders | Marea | 0 | 30-12-2007 21:57 |
| stilo line out?? | Steely | I.C.E | 7 | 18-12-2007 19:17 |
| My line driver for sale Audiobahn | Alfie | Auction Watch | 0 | 18-09-2005 21:27 |
| | 84jr0 | Stilo | 6 | 03-09-2005 14:12 |
