| fuse blown? i jsut got a griffin tuneflex AUX from halfords (its ment to charge ipod and then play it through aux-in on HU) using the ciggerete lighter socket. i was trying to find a good position for it when there was a little click sound and now there is no power going to my HU and lighter socket? can sum1 tell me where the fuses are located? cheers ![]()
| *custom name* | Re: fuse blown? whats the car? fuses are usually located to the side of the dash at drivers side depending on car. usually 10-15amps. in the stilo its f39
__________________ ![]() "its ok, at 100MPH the needle sits over the airbag light" lol | ||
| | #3 | ||
| Re: fuse blown? fiat punto mk1 99T
| | #4 | ||
| Low Rider.............. | Re: fuse blown? drivers side, like jonny sed get a torch on it.. you'll see the one thats blown iirc its a red fuse 10a
__________________ Stilo, Private Plate, Black Chrome 17" Blades, GSR'd, Lowered 50mm on Eibach Kit, Wind Deflectors, Fiat Sun Shades, BIG ICE, Abarth Badges, Debadged Rear, Abarth Body Kit, Fully Colour Coded, Debadged Grill with Added Fiat Badge, Detailed Engine Bay, Painted Callipers, Richbrook Arial | ||
| | #5 | ||
| Re: fuse blown? ok i found the fuses. how do i take them out check them?
| | #6 | ||
| *custom name* | Re: fuse blown? pull on them, theyre usually transparent anyway, view them from the side and you should see which one is blown
| The following user says "Thank You!" to j0nny for this useful post: | ||
willboyes (23-07-2008) | ||
| blown fuse | cabra | Ducato | 0 | 26-10-2007 20:27 |
| blown radio fuse | gaz.d | Panda (Classic) | 9 | 20-08-2007 09:30 |
| Fuse blown , i think? | PuntoMkey | Punto > Technical | 1 | 07-04-2007 18:19 |
| Reasons for blown fuse | 4paws | Uno > Technical | 2 | 27-02-2007 05:21 |
| blown fuse | popozuda52 | Bravo/a > Technical | 5 | 09-06-2006 18:14 |
