The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 16-07-2008   #1
Trader Rating: (0)
Question Fiat Punto mkII 2000 stereo No power??
Hi all,
A week or so ago my stereo just died for no reason, thought it was the stereo so bought another one, then found that the new one didn't work either.
Basically what happens is that the stereo is just dead, no power at all. I have taken out all the fuses and checked them and they are all fine. The only one that seems to keep on blowing is the ceiling light one? I can't seem to work out why. Is this connected to the stereo?
Have looked through the handbook and nowhere does it state a fuse for the stereo?
Checked all fuses inside and under the bonnet and they are all fine
Any ideas why it wouldn't be getting any power or why the ceiling light fuse would keep on blowing?
Its driving me crazy not having a stereo!!!
mintys24-7 is offline
Old 16-07-2008   #2
Trader Rating: (0)
Re: Fiat Punto mkII 2000 stereo No power??
i think IIRC that light fuses and stereo' are on the same loop
So if the lights blown - stereo' wont work either
Ziggy
Ziggy122 is offline
Old 16-07-2008   #3
Xen
FFFTW!
Xen's Avatar
Trader Rating: (0)
Xen has donated! United Kingdom
Yep - Fuse 39 - Powers front light, boot light, diagnostics socket and headunit.
You must have a short somewhere. I'd be tempted to disconnect the connectors to both lights and replace the fuse. If it doesn't blow, the short is in one of the lights. That will narrow down your search.
If my post has helped you, please click the Thanks button Cheers.
Xen is offline
Old 16-07-2008   #4
Trader Rating: (0)
Just took out the ceiling light and neither of the bulbs look like they are blown. So where is this fabled diagnostics socket and what do i need to do if it is broken?
Old 16-07-2008   #5
Trader Rating: (0)
diagnostic socket is in the fusebox on the drivers side. when does the fuse blow? does it happen when the ceiling light should be on - does it blow when the door is opened for example? or the boot? or when you turn the stereo on?
you could completely unplug the ceiling light as suggested above then replace the fuse and test the stereo. I know some stereos wire slightly differently, yellow and red joined for some, could this be the cause or some kind of shorting? or arching?
thombeal is offline
Old 16-07-2008   #6
Trader Rating: (0)
Just took out the ceiling lights and it seems to be my stereo that everytime i plug it in it seems to blow the fuse. Guess there must be a short somewhere inside the stereo which is causing it?
Thanks alot for the help anyways been really useful! Maybe i'll have a stereo working tomorrow!!
Old 16-07-2008   #7
Trader Rating: (0)
thought you had tried it with another stereo? if so then its not within the unit but the wiring.
thombeal is offline
vB code is On
Punto 1.2 2000 Loss of Power owenh123 Punto > Technical 1 06-07-2008 18:39
2000 MkII 1.2 ELX 8v Punto Won't Start! mikeeffect Punto 10 24-03-2008 19:58
MP3 Player To Punto MKII Stereo fouldsc I.C.E 3 20-07-2007 07:25
