| Right, I have plans, but might have power issues? Right, after giving it some thought, I have decided on a setup. I'm getting a vibe blackbox stereo 4 to power my front and rear speakers (its a 4 channel amp in case you hadn't guessed), and believe it has high level inputs (I can link it to some speaker terminals of the head unit, rather than using the RCA). Along with this, i'm getting a vibe CBR12 active EVO sub for the boot, which I intend to hook up the RCA plugs in the HU. My questions are, what additional power sources will I require? (I imagine I cant run all that off my battery with it going flat), and how will I have to set it up? Is it a case of power caps, etc, for something more? Any help would be a appreciated, Chris.
__________________ Fiat Punto Mk2 2003 1.2 Owner ![]() Ice- JBL & Fli Coax, Fli 800s Amp.... Coming Soon! - CBR 12 Active EVO, Blackbox Stereo 4 Amplifier, Blackair Components 6.5" Fronts JBL T696LTD Rears....now were getting somewhere | |||
| Re: Right, I have plans, but might have power issues? Use rca rather than high inputs if you can because it will be better. get some nice fat 4 awg gauge cable from the battery to boot, into distribution block and ideally more 4 gauge cable to each amp. Earthed using same gauge. People say both positive and negative things about power caps. I believe 2nd batteries are only required if you're wanting to run the system with engine off without draining main battery. it should run off standard battery fine. If not you can consider various upgrades but i'd install it first and see how it is. Obviously you'd need the engine on when running the system on max or the battery won't stand a chance!
| The following user says "Thank You!" to thombeal for this useful post: | ||
chris18790 (06-07-2008) | ||
| | #3 | ||
| *custom name* | Re: Right, I have plans, but might have power issues? theres going to be no mention on power caps, sick of writing about them. i cant imagine there being any big problem there in terms of power. just use the correct cable as thombeal said, try not to run the system while the car is off for long periods to keep the battery charging and you should be fine
__________________ ![]() "its ok, at 100MPH the needle sits over the airbag light" lol | ||
| | #4 | ||
| Re: Right, I have plans, but might have power issues? Cheers for the replies guys, just a few more questions.
| | #5 | ||
| Re: Right, I have plans, but might have power issues? shouldn't bother with second battery at all. just use decent power cables. I think all (or at least most) amps have RCA in and RCA through, so you can use RCA through to take the unaffected signal into a second amp.
| | #6 | ||
| *custom name* | Re: Right, I have plans, but might have power issues? sound have sound in and sound out ports on the amp, if not the onli option is to use phono y splitters dont bother with 2nd battery! upgrade existing one before you do that.
| | #7 | ||
| Re: Right, I have plans, but might have power issues? doesn't y splitters half the power? does that matter? amp in and out should boost the power shouldn't it? or at least not lose power.
| | #8 | ||
| TJet powaaaaaaa | Re: Right, I have plans, but might have power issues? You wont need a second battery for what you want to to its not a big install tbh. Just use 4 gauge and avoid power caps they are a waste of money.
| | #9 | ||
| *custom name* | Re: Right, I have plans, but might have power issues? its phono leads, the used to send sound signals, not power, but it does split this, has less of an effect than if it was power, but if the amp doesnt have a sound out port, which quite a few dont. then that will be his onli option. in fairness theres a few headunits out there which onli have on rca output for sub so needs to be split to go into amp
| | #10 | |||||
| | #11 | ||
| Re: Right, I have plans, but might have power issues? Well if I am correct the vibe blackbox stereo 4 amplifier has an RCA out...thing (not sure of the correct terminology). If this is the case, could I then just bring the RCA cables from the H/U, plug them into the RCA in for the blackbox 4 (powering the 4 door speakers), and then have another RCA cable going from the blackbox amplifier to the CBR 12 amplifier (for the subwoofer)? If im being a bit unclear I'll provide an image if necessary. Chris.
| | #12 | ||
| Re: Right, I have plans, but might have power issues? that makes sense to me. should be fine!
chris18790 (09-07-2008) | ||
| | #13 | ||
| Re: Right, I have plans, but might have power issues? Cheers for the clarification thombeal, thanks again
| | #14 | ||
| Re: Right, I have plans, but might have power issues? no probs. let me know how u get on.
| | #15 | ||
| Re: Right, I have plans, but might have power issues? Right, I've just drawn up a little image (sorry its a bit messy) but have a look and see if that looks about right. ![]()
| Tags: battery, cap, capacitor, power, powercap |
| Mk2 1.4 i.e power issues!! | 601176005 | Uno > Technical | 0 | 01-12-2007 17:07 |
| Punto power issues | keeeno | Punto > Technical | 9 | 14-02-2007 22:12 |
| Power Steering Issues | dwdrumtastic | Punto > Technical | 10 | 06-01-2006 17:50 |
| I.C.E How to - Power Issues | Luke | I.C.E | 9 | 21-07-2005 12:40 |
| Power Issues | Luke | ICE Guides | 0 | 20-03-2005 11:59 |
