| Ray Von | Trouble with rear speaker wires into amp... So tonight I decided to dust off my old JL sub and my amp and get some better quality bass in the GP I wired everything up with the exception of taking the wires from my rear speaker and sticking some RCA connections on the end. The amp turned on fine etc but there was no sound coming from ANY of the speakers in the car. I turned the amp off and removed the input and the speakers worked again, but now they're distorted even at low volume. Can anybody tell me whats going on and if I could have permanantly damaged my speakers??
__________________ | ||
| | #2 | |||||
| Re: Trouble with rear speaker wires into amp...
Does this mean you joined RCA plugs to your speaker cable? Speaker output from the HU is a higher power than the RCA as the HU is the amplifier to the speaker whereas the RCA is not amplified because the amp in the boot does that. So if you took the speaker cable from the HU into the amp but putting RCA plugs on one end you would have put too much power into the amp and could damage that. I don't fully understand what you meant by the above quote so can't be sure how relevant my answer is.
| | #3 | |||
| Ray Von | Re: Trouble with rear speaker wires into amp...
The amp itself seems fine?
__________________ Last edited by puntokris : 03-07-2008 at 10:47. | |||
| | #4 | ||
| Re: Trouble with rear speaker wires into amp... That's gonna put far too much power into the amp and i guess could damage the speakers and/or amp because its amping an already amplified signal. You either need to run RCA cable from the pre-out on the back of HU into the RCA on the amp, OR using the speaker out on the HU into a high level input on you amp if it has one, but that won't be such good quality and not all amps have one.
| | #5 | |||
I have a separate low pass filter with a high level input on it lying around I could use that... The speakers are distorted even with the amp disconnected. Is this lasting damage and if so does it mean new speakers or a new H/U?? Might be a good excuse to get some good ones.
__________________ | |||
| | #6 | ||
| Re: Trouble with rear speaker wires into amp... If I'm reading this right, you put speaker power from your headunit into the RCA input of your amp? If that's the case, you've more than likely knackered the amp.
__________________ Black 100HP Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller. Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier. Chord Epic speaker cable and Anthem RCA leads. | |||
| | #7 | ||
| Mo Money, Mo bass | Re: Trouble with rear speaker wires into amp... What amp is it? Could have given more than the Peak Power of them. I have a BNIB set of these possibly for sale http://caraudiosecurity.com/shop/pro...s_id/5772.html Unless your going to go for the big guns
| | #8 | |||||
| | #9 | ||||||
Honestly I f*cking hate car electrics. Give me an engine and I could bore you all day. Give me a crimping tool and I honestly want to cry.
__________________ | ||||||
| | #10 | ||
| Re: Trouble with rear speaker wires into amp... your amp could well be fine, just won't know for sure until you test it on speakers that work! just make sure you run proper RCA cables from pre-out of HU!
| | #11 | |||
BUT its the front speakers that are distorted, they are standard speakers that are running alongside the standard H/U, these haven't even been touched I can't understand why they sound knackered.
| | #12 | ||
| Re: Trouble with rear speaker wires into amp... well from what you said i can't imagine the HU is damaged though i may be wrong. have you done anything to the wiring on the back of the HU? could wires have been crossed? loose connection? my front speakers used to crackle when it went loud thought i had blown one but it was just a loose wire.
| | #13 | |||
It does make the distorted noise my front speakers in my mk2 made when the wires were crossed.
| | #14 | ||
| Re: Trouble with rear speaker wires into amp... a lot of things are coincidences. Front speakers happened to blow or become loose after connecting rear speakers to amp. could be completely unrelated. could you have pulled wires loose when moving the rear speaker wire? disturbing wiring at the front of the car? did sound come from the front speakers when you were testing the amp?
| | #15 | |||
When I tested the amp, nothing in the car made any sound whatsoever. Then after I disconnected the amp the speakers were fooked.
| Rear speaker wires?? red/yellow +/-??? | eddt1 | Punto | 0 | 22-03-2008 12:00 |
| Speaker Wires | venney | I.C.E | 3 | 14-08-2007 17:43 |
| Punto Rear Speaker Wires | icebox | Punto > Technical | 1 | 28-03-2006 14:48 |
| marea rear speaker wires? | task | I.C.E | 1 | 09-01-2006 19:19 |
| Speaker Wires | Babysei | Cinquecento / Seicento | 7 | 19-03-2003 00:56 |
