The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 28-06-2008   #1
Trader Rating: (0)
Please advise me on my proposed new system!!!
Pioneer HU:
http://caraudiosecurity.com/shop/pro...s_id/7966.html
Amp: Legacy, 4 channel, 1000W
http://caraudiosecurity.com/shop/pro...s_id/5837.html
Comps: Pioneer 17s
http://caraudiosecurity.com/shop/pro...s_id/8492.html
Sub: Pioneer 10"
http://caraudiosecurity.com/shop/pro...s_id/6554.html
Please let me know if the watt/current flow dosnt add up before i set my car on fire or something. And any tips on a better system (for the same money) would also be welcomed...
thanks
Major365 is offline
Old 30-06-2008   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: Please advise me on my proposed new system!!!
the headunit only has 1 pre-out, so you can only amp the sub, or you would need to use a splitter, which is enver a good idea. that means there is no point buying a 4 channel amp if you cant use all 4 channels.
the components are only 35w, which is pretty crap even to be run of the headunit. you want at least 50wRMS (only rms matters), although for amping you want 75-100wRMS.
the sub is fine, actually i like that particular sub it sounds better than you'd expect a 350w sub to be.
jug is offline
Old 01-07-2008   #3
Trader Rating: (0)
ok, so how many pre-outs do i need on my h/u?
and you say i definatly need some heavier components.
thanks for your help!
Major365 is offline
Old 03-07-2008   #4
Trader Rating: (0)
i thought a 4 channel amp used one input but i guess i could be wrong.
some amps have RCA through so you take the one pre-out to the input on the amp, then the through is the unaffected signal which you can take to another amp.
more pre-outs mean you have more control from the HU also though. eg. front/rear fade & sub volume.
so pre-out 1 could be used to amp front speakers. pre-out 2 could be for amped rear speakers (if fitted) or sub (if you set lpf correctly) and some HUs have a sub out also which i guess has some form or lpf anyway although probably still want to use the one on the amp too.
thombeal is offline
Old 07-07-2008   #5
Trader Rating: (0)
your best bet is buy a fusion ca-cd500 its £150 but has loads of features and has 3 pre out which is best one for front speaker, one for rear and one for sub, i dunno what ur budget is but ive spend nearly £1000 on my system and i have the head unit i just told u, kicker 15 inch L7 powered by a directed d2400 and two sets of jbl gto 6507 componants powered off of a 4 channel jbl gto-1004e, plus wireing kits and sill things, sound great plently of bass but not much boot space lol. but this is my choice hope u get some ideas
buda1987 is offline
Old 08-07-2008   #6
jug
jug's Avatar
Trader Rating: (1)
for your 4 chanel amp you need 2 pre-outs, one sub and one rear.
jug is offline
Old 08-07-2008   #7
Trader Rating: (0)
i would use a 4 channle amp to power componants and a mono block for the sub its the best combo plus u can use a 4 channle with 2 pre outs. one for front and one for sub all you do is your aux leads go into the front input of the 4 channle amp, there will be a output connection for the aux leads all u do is buy a short aux lead from the output and put it into the rear input if i can get some pics to show how its done ill post them soon
buda1987 is offline
Old 09-07-2008   #8
More ICE Please
volxstu's Avatar
Trader Rating: (0)
volxstu has donated! United Kingdom
Splitting the RCA voltage lower the Voltage the lower the qulity of signal the amp receives but on such a system i dont think you would notice much of a difference.
Originally Posted by Tris Harris View Post
I have tried to stay on here incase anything remotely interesting popped up me...
a chocolate finger sounds good
volxstu is offline
vB code is On
The Proposed New Insurance System StevenRB45 Insurance 2 05-10-2007 10:03
Proposed changes to MOT system Liam Leisure Lounge 29 01-12-2006 16:47
Proposed new rules for the 2012 Olympics :D Koa Leisure Lounge 5 16-07-2005 19:23
Can anyone advise me on Cinq ICE system please? futurshox I.C.E 18 27-01-2004 16:12
