The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 11-06-2008   #1
Trader Rating: (0)
wiring problem subs to amp
i have two pionner 1200w champion series subs in separate boxes with a 3000w loudest amp my amp looks like this - - + +
i have wired atm the negatives from each sub to the two negatives on the amp and the two positives from each sub to the two positives on the amp is this correct please help me sorry dnt know how to up load a diagram of what i have done
liam123 is offline
Old 11-06-2008   #2
Trader Rating: (0)
Re: wiring problem subs to amp
From what I've seen on most amps if you have two subs then you should wire it like so................
+ SUB 2
+ SUB 1
- SUB 1
- SUB 2
(Imagine that turned on it's side to look like your little diagram)
Every amp I've ever used were wired like so but yoursmay be different.
ne1l is offline
The following user says "Thank You!" to ne1l for this useful post:
liam123 (11-06-2008)
Old 11-06-2008   #3
Ah. Not good...
chaos's Avatar
Trader Rating: (1)
chaos has donated! United Kingdom
Is it a 2 channel amp or a mono amp?
Chaos - Life wouldn't be the same without it.
Cinq parts clearout!
chaos is offline
Old 11-06-2008   #4
Trader Rating: (0)
its a monoblock amp which look like this on the side --++
liam123 is offline
Old 12-06-2008   #5
More ICE Please
volxstu's Avatar
Trader Rating: (0)
volxstu has donated! United Kingdom
Ahh you need to wire to 2 ohms then
Ignore the green wires.
Or in word wire the +on sub 2 to to the + on sub one, same with the - and then the + from 1 to amp and same with -
Originally Posted by Tris Harris View Post
I have tried to stay on here incase anything remotely interesting popped up me...
a chocolate finger sounds good
volxstu is offline
Old 12-06-2008   #6
More ICE Please
volxstu's Avatar
Trader Rating: (0)
sorry forgot link
volxstu is offline
Old 12-06-2008   #7
Ah. Not good...
chaos's Avatar
Trader Rating: (1)
What model subs are they?
chaos is offline
Old 12-06-2008   #8
Trader Rating: (0)
they are pioneer 1200watt champion series subs
liam123 is offline
Old 12-06-2008   #9
Ah. Not good...
chaos's Avatar
Trader Rating: (1)
That's not what I meant - what voice coil config, since they come in more than one IIRC.
chaos is offline
Old 12-06-2008   #10
Trader Rating: (0)
Ts-w307d2
liam123 is offline
Old 13-06-2008   #11
More ICE Please
volxstu's Avatar
Trader Rating: (0)
Well aparently it is dual 2ohm and i believe that the amp claims to be stable at 1 if you wanted to wire it like that but then you run the risk of overpowering them but do we believe the loudest's RMS Claims
volxstu is offline
Old 13-06-2008   #12
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
Not really!!!
Anyways....
If they are dual 2 ohm that means either 2 x 4ohms or 2 x 1ohm, so either way can show the amp 2ohms. Just don't wire them so they show 0.5ohm or chances are the amp will go into protection mode or up in flames!
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
Chord Epic speaker cable and Anthem RCA leads.
paulbfd is offline
Old 13-06-2008   #13
More ICE Please
volxstu's Avatar
Trader Rating: (0)
Originally Posted by paulbfd View Post
Not really!!!
Anyways....
That thing will prob do that at 4ohms
volxstu is offline
vB code is On
wiring help subs to amp liam123 I.C.E 0 11-06-2008 18:21
For Sale: Twin Vibe Subs, Inphase Amp, Vibe Sub, JL Audio Amp (Speakers) puntobadboi For Sale / Wanted 0 20-11-2006 14:26
Keeping Factory Headunit, Installing Amps subs and uprated wiring. help please potty I.C.E 8 06-09-2006 04:45
Wiring 2 Subs to 4 Channel Amp jdunderhill I.C.E 4 19-04-2004 23:36
amp wiring problem. scottg Punto > Technical 1 07-04-2004 06:17
