| ok, ive been wondering about this for quite a while, and thought i'd bring it to the table with you guys. all things considered, there is a specific volume requited in a box behind a standard mounted subwoofer, should this volume remain the same when the sub is inverted? should the sub be wired the opposite way round... so as to make the cone run the opposite direction to as it would if mounted standard. can a smaller (obviously not drastically smaller) enclosre be used? sound differences? better worse? i have 2 pioneer tws306c subwoofers... usually standard mounted... would they be suitable to flip and reverse mount? thanks, hope to hear some interesting replies ![]() (apologies for the ramble lol)
__________________ Dr Hillmann Seicento SX - Breaking for spares All in classifieds PGT wheels for sale... | |||
| Re: Reverse mounted subwoofer... Your specs should give you the subs displacement. If they need 0.75ft3 with sub, and the sub displacement is 0.15ft3, then you want 0.60ft3. However, sometimes an oversized box can give a flatter response and better SQ, with a slight drop in power handling. Technically you need to flip the phase too, but try it both ways and see which sounds best. Sounds different? Possibly, but you'd have to have a very keen ear to tell.
__________________ Black 100HP Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller. Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier. Chord Epic speaker cable and Anthem RCA leads. | |||
| | #3 | ||
| More ICE Please | Re: Reverse mounted subwoofer... You do need to switch phase i didnt once and tht sub didnt last long. | ||
| | #4 | ||
| Re: Reverse mounted subwoofer... No you don't. I ran my Macdaddy out of phase for months with no problems.
| | #5 | ||
| More ICE Please | Re: Reverse mounted subwoofer... Spose it depends on the kind of set up you have then. Looks like a little research is in order to find the science behind it then. WTS | ||
| Getting mounted | dpr59 | Leisure Lounge | 24 | 19-05-2008 17:29 |
| roof mounted screen fitting | toad101 | I.C.E | 4 | 17-02-2007 12:36 |
| Sporting, Reverse gear stopped working... reverse inhibitor? | Eiteews | Cinq/Sei > Technical | 2 | 01-12-2005 11:08 |
| does anybody have a wing mounted aerial? | christopher watson | Panda (Classic) | 2 | 05-10-2005 16:51 |
| New ECU mounted | Fred_Sweden | Punto > Technical | 13 | 27-01-2004 04:05 |
