The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 07-06-2008   #1
dr_hillmann's Avatar
Trader Rating: (0)
Question Reverse mounted subwoofer...
ok, ive been wondering about this for quite a while, and thought i'd bring it to the table with you guys.
all things considered, there is a specific volume requited in a box behind a standard mounted subwoofer, should this volume remain the same when the sub is inverted?
should the sub be wired the opposite way round... so as to make the cone run the opposite direction to as it would if mounted standard.
can a smaller (obviously not drastically smaller) enclosre be used?
sound differences? better worse?
i have 2 pioneer tws306c subwoofers... usually standard mounted... would they be suitable to flip and reverse mount?
thanks, hope to hear some interesting replies (apologies for the ramble lol)
Dr Hillmann
Seicento SX - Breaking for spares
All in classifieds
PGT wheels for sale...
dr_hillmann is offline
Old 07-06-2008   #2
paulbfd's Avatar
Trader Rating: (0)
paulbfd has donated! United Kingdom
Re: Reverse mounted subwoofer...
Your specs should give you the subs displacement.
If they need 0.75ft3 with sub, and the sub displacement is 0.15ft3, then you want 0.60ft3. However, sometimes an oversized box can give a flatter response and better SQ, with a slight drop in power handling.
Technically you need to flip the phase too, but try it both ways and see which sounds best.
Sounds different? Possibly, but you'd have to have a very keen ear to tell.
Black 100HP
Alpine CDA-7944, PXA-H701 processor and RUX-C701 controller.
Hertz Mille MLK2 components, Mille 10" subwoofer and HP4 amplifier.
Chord Epic speaker cable and Anthem RCA leads.
paulbfd is offline
Old 07-06-2008   #3
More ICE Please
volxstu's Avatar
Trader Rating: (0)
volxstu has donated! United Kingdom
You do need to switch phase i didnt once and tht sub didnt last long.
Originally Posted by Tris Harris View Post
I have tried to stay on here incase anything remotely interesting popped up me...
a chocolate finger sounds good
volxstu is offline
Old 09-06-2008   #4
paulbfd's Avatar
Trader Rating: (0)
No you don't.
I ran my Macdaddy out of phase for months with no problems.
Black 100HP
paulbfd is offline
Old 10-06-2008   #5
More ICE Please
volxstu's Avatar
Trader Rating: (0)
Spose it depends on the kind of set up you have then. Looks like a little research is in order to find the science behind it then. WTS
volxstu is offline
vB code is On
Getting mounted dpr59 Leisure Lounge 24 19-05-2008 17:29
roof mounted screen fitting toad101 I.C.E 4 17-02-2007 12:36
Sporting, Reverse gear stopped working... reverse inhibitor? Eiteews Cinq/Sei > Technical 2 01-12-2005 11:08
does anybody have a wing mounted aerial? christopher watson Panda (Classic) 2 05-10-2005 16:51
New ECU mounted Fred_Sweden Punto > Technical 13 27-01-2004 04:05
