The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 02-06-2008   #1
Brooksy's Avatar
Trader Rating: (0)
Brooksy has donated! United Kingdom
ground loop islolator
i fitted my ground loop isolator today cos i was having a lot of interference, but when its plugged in my sub wont work at all but the amp is showing power, when i unplug it my sub works fine, anyone got any ideas what this could be?
Brooksy is offline
Old 02-06-2008   #2
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
Re: ground loop islolator
thats strange. these things usually work a treat.
defnitly connected the right way?
check continuity between the connections
have you checked for the reasons for interferance?
is the audio cables running along the same side as the power wires?
do they cross any of the electrical supply wires?
1.2 3dr stilo dropped on claws & a suzuki bandit v
j0nny is offline
Old 02-06-2008   #3
Brooksy's Avatar
Trader Rating: (0)
yes the wires run down the same side of the car thats where the interference is coming from but to be honest i'm more concerned about why the GLI isn't allowing the sub to work
Brooksy is offline
Old 02-06-2008   #4
*custom name*
j0nny's Avatar
Trader Rating: (0)
with ground loop isolators you loose a bit of the signal as theyre not 100% effective but there may be a connection break inside it? thats why i said check the continuity to see that a flow is still going from one end to the other
also i take it your using pre outs. due to the low frequency output of these it may have more of an effect on the signal than speakers but you shud still hear something
j0nny is offline
Old 02-06-2008   #5
Trader Rating: (0)
you need to put the ground loop isolator on the rca lead which is used for the speakers mate it cripples the subwoofer output else
swinisskill is offline
Old 02-06-2008   #6
Brooksy's Avatar
Trader Rating: (0)
it is plugged into the amp that's powering the sub, the sub works fine when the GLI is unplugged but doesn't work at all when it is plugged in,yeas it is plugged into the rca leads
Brooksy is offline
Old 02-06-2008   #7
Brooksy's Avatar
Trader Rating: (0)
i got the multimeter out and there is no reading when i test the GLI so should i take it back and get a new one?
Brooksy is offline
Old 02-06-2008   #8
Xen
FFFTW!
Xen's Avatar
Trader Rating: (0)
Xen has donated! United Kingdom
you wont get a continuity reading from one side to the other on a GLI - they work through electromagnetism and induction and so are completely isolated (hence ground loop isolator ) if they did have continuity, that would defeat the whole objective.
Because they work through induction, and low frequency signals at such a low current produce very little electromagnetism, so they arn't really ideal with subs. Also, due to the secondary coil within the GLI, some subs just detect it as a short and cut out - check to see if the amp has a fault light and if it is illuminated.
I may write a guide on GLIs, seems to be a lot of confusion regarding them. Personally i dislike GLIs because as i've mentioned many times before, there not 100% efficient, often causing excessive signal drain, and so reduce sound quality. Its like seeing rust on a car and just painting over it - the final result is not as good as it would be if you tackled the root of the problem.
If my post has helped you, please click the Thanks button Cheers.
Xen is offline
Old 04-06-2008   #9
*custom name*
j0nny's Avatar
Trader Rating: (0)
xen i would actually like to read that. i read the packaging and guide and have installed them. though i have never took them apart to see how they work so this would be a good read
j0nny is offline
vB code is On
Ground loop isolator MattMk1 I.C.E 4 23-12-2007 17:35
lambda sensor open loop ? ycming Cinq/Sei > Technical 6 08-06-2007 19:24
O2 rewards for O2 users, loop hole? Liam Leisure Lounge 0 23-01-2007 08:36
Blue key 'keyring attachment' loop broken off tony witney Bravo/a > Technical 14 20-10-2005 19:36
Closing the loop davemarsh Site Ideas 3 07-05-2004 19:53
