The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 30-05-2008   #1
Trader Rating: (0)
Question weezing noise from 6x9's
just fitted my new 6x9's and when i rev the engine this noise gets louder form my speakers, im running them from my amp, does anybody have any idea what this is and how to stop it??
cheers guys....
punto_pete07 is offline
Old 01-06-2008   #2
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
Re: weezing noise from 6x9's
ground loop isolotar. can get it from any good ice dealer. just cuts out the alternator noise which this is likely to be
also are they amped? cos the speaker wire will prob be crossing a live feed line which could also cause this
"its ok, at 100MPH the needle sits over the airbag light" lol
j0nny is offline
Old 01-06-2008   #3
Xen
FFFTW!
Xen's Avatar
Trader Rating: (0)
Xen has donated! United Kingdom
It could be the signal (line-level) line. High-level signals suffer very little from EMI.
Ground loop would probably fix this, but you will loose a slight amount of quality due to the way GLIs work - its basically a transformer relying on electromagnetic energy through induction and so there never 100% efficient.
If my post has helped you, please click the Thanks button Cheers.
Xen is offline
Old 01-06-2008   #4
Trader Rating: (0)
cheers,
yes thay are amped, mate told me that it could be bad earth????
what would i need to get from the i.c.e shop to stop this noise??
thanks guys
Old 01-06-2008   #5
Xen
FFFTW!
Xen's Avatar
Trader Rating: (0)
bad earth is a possibility... read the ICE guide to clarify possible issues...
http://www.fiatforum.com/ice-guides/...y-what-do.html
Xen is offline
Old 02-06-2008   #6
Trader Rating: (0)
sounds exactly the same as my problem
mine is fine now after i changed my earth point
JakePuntoVanMan is offline
Old 03-06-2008   #7
Trader Rating: (0)
where did you change your earth to? i got mine at the seat belt bolt. what is the best place??
Old 04-06-2008   #8
Xen
FFFTW!
Xen's Avatar
Trader Rating: (0)
Not really ideal tbh. Is it a MK2? on the MK2, theres an earthing point behind the carpet that covers the 'lip' of the boot near the passenger side. Its used for all the rear lights and fiats subwoofer so it should be ideal.
Xen is offline
vB code is On
JBL 6x9's pk090 I.C.E 4 28-03-2008 13:13
6x9's richydraper I.C.E 3 03-05-2007 12:54
6x9's + tv =..... beau Leisure Lounge 22 10-05-2006 19:55
4 6x9's GhettoMoose I.C.E 13 24-03-2005 22:43
Which amp for my 6x9's??? dajoebomb I.C.E 4 20-03-2005 22:47
