The FIAT Forum
Go Back   The FIAT Forum > Miscellaneous > I.C.E
Old 23-05-2008   #1
Trader Rating: (0)
Little help with Punto Mk2 (03) speakers please :)
Hey everyone! This is my first post in the forum so excuse any mistakes I make
Anyway, onto the topic, I have a problem.
I am currently looking to replace my front door speakers in my Punto (Mk2 2003 in case you missed the topic title), and am looking for some replacements.
Now, getting them out isn't and issue as i've already had most of the door off , thank god for the Haynes manuals .
Only problem ive got is, I want a nice simple swap over if possible, just but a new set, take the old ones out, and screw the new ones in the same place, without any faff.
What I need to know is, what size are the current speakers? Ive measured them, and found a result of 165mm, or their about, which if im right equates to about 6.5 inches, but im not entirely sure im right. So my question is, are the speakers 165mm (6.5 inch), or would I have to get a 170mm speaker instead?
Last but not least, does anybody happen to know the mounting depth in the doors, becuase the last thing I want to do is find a good pair of speakers and then realise they are too deep for the doors
Any help, (and even speaker recommendations!) would be greatly apprieciated guys.
Many thanks, Chris.
p.s - I checked the speaker data stickied topic, but I couldn't quite make a straight answer out of it.
chris18790 is offline
Old 23-05-2008   #2
*custom name*
j0nny's Avatar
Trader Rating: (0)
j0nny has donated! United Kingdom
Re: Little help with Punto Mk2 (03) speakers please :)
there are hundreds of 165mm speakers available and im not sure off hand but this is likely to be the size as a lot of fiats car in the last few years have commonly had 165mm speakers
in terms of depth, this is usually quite hard to obtain as no speaker manafacturer has it listed and its not exactly on fiat specs so without someone measuring its hard to know. im sure theres a few punto owners will tell ya what theyve got and what fits etc. There are how ever adapters available to fit your and leave you with a bigger depth and the right holes to fit a new speaker. one of the cheapest place is nexxia. yours is a few down in this page: http://www.nexxia.co.uk/Speaker_adaptors/fiat.htm
"its ok, at 100MPH the needle sits over the airbag light" lol
j0nny is offline
Old 23-05-2008   #3
Trader Rating: (0)
Thanks j0nny I apprieciate your help, but i've just thought of another slight problem. By my reckoning, 165mm is 6.5 inches, but a lot of these aftermarket speakers say things like "6.5 inch/17cm" (obviously 170mm), you that still be the right size speaker? Or would it have to be a 6.5 inch/165mm?
Thanks, Chris
Fiat Punto Mk2 2003 1.2 Owner
Ice- JBL & Fli Coax, Fli 800s Amp....
Coming Soon! - CBR 12 Active EVO, Blackbox Stereo 4 Amplifier, Blackair Components 6.5" Fronts JBL T696LTD Rears....now were getting somewhere
Old 23-05-2008   #4
*custom name*
j0nny's Avatar
Trader Rating: (0)
when on our audio board our measurements are all give in metric and on the packaging this is usually the main dimension and sometimes helps defnite the product name, the imperial measurement is only given for handiness of people who still use the old system. so you shud be able to find out very easily what size the speaker is. 16.5cm is very common, my car's four and ive a few in the house. lot of makes produce their range in all sizes so this most certainly will be included
EDIT: 17cm speakers are made too, just to clarify. example, alpine type r components are made in both 16.5cm and 17cm, theyre different sizes and 17 wont fit in 16.5cm hole without minor modification. plus theyre prob going to have a bigger depth due to being that bit bigger.
j0nny is offline
Old 23-05-2008   #5
More ICE Please
volxstu's Avatar
Trader Rating: (0)
volxstu has donated! United Kingdom
Wot just get 6.5 inch speakers they fit if you get the infinity components they do. a shallow magnet so they will fit
Originally Posted by Tris Harris View Post
I have tried to stay on here incase anything remotely interesting popped up me...
a chocolate finger sounds good
volxstu is offline
Old 23-05-2008   #6
Trader Rating: (0)
sid23456 has donated!
the mounting depth is about 46mm with the windows down
can get a few more mm using the autoleads speaker adapters, or making your own door pods
are you after component speakers?
sid23456 is offline
Old 30-05-2008   #7
Trader Rating: (0)
Thanks for the replies guys, and to answer the questions, I think I would prefer some coxials, as they seem easier to fit than a set of components, at least until I feel a bit more confident with fitting speakers.
An suggestions for a good set then? (Anything under £100 if possible please)
Thanks.
vB code is On
Punto mk2 Speakers punto maniac Punto 2 10-03-2008 18:13
what speakers for my MK2 Punto? Fidgit I.C.E 0 13-11-2006 23:45
Speakers in Mk2 Punto sunny2539 I.C.E 4 09-11-2006 20:41
Speakers in Mk2 Punto sunny2539 I.C.E 0 08-11-2006 17:59
Rear Speakers Punto mk2 sunny2539 I.C.E 38 30-01-2006 11:28
